-   -   Removing tar/asphalt from car. (http://forums.pelicanparts.com/off-topic-discussions/715466-removing-tar-asphalt-car.html)
CHICKS 11-08-2012 04:41 PM
Originally Posted by tchanson (Post 7079434)
This or 3m adhesive remover in the spray can found in the automotive section of walmart.
drcoastline 11-08-2012 05:18 PM
Anything petroleum based will work but Diesel or Keorsene won't damage the paint. And much, much cheaper than Goof off or Goo Gone althoguh they are good products and will work also.
MT930 11-08-2012 06:13 PM
That stuff is pretty great, I use it alot.
futuresoptions 11-08-2012 09:49 PM
Didn't your dads teach you guys to keep a bottle of Ronsonol or Zippo lighter fluid in the garage for this purpose... Geez, it even says on the bottle/can that it removes tar... Works great on that sticky glue from price tags too fwiw...
stealthn 11-10-2012 09:27 AM
Since nobody said it I will: peanut butter
Safest stuff for your car
HarryD 11-12-2012 06:08 AM
Originally Posted by GWN7 (Post 7078779)
Prep Solv. Same thing happened with my truck. I went to my body shop guy and he came out with Prep Solv and a handful of rags. Wet rags and wipe till clean. Then apply a coat of wax. Prep Solv is what body shops use to remove wax and other crud before painting.
Prep Solv is typically 3 parts VM&P Naptha and 1 part paint thinner. Works great to clean all types of things.
Sometimes, I just use VM&P Naptha (also known as lighter fluid and Coleman fuel).
cairns 11-12-2012 08:08 AM
Xenit from Stoner's is BY FAR the best IMO. 3M is close but Xenit is an aerosol spray hence a lot easier to apply. Works very well on cosmoline too. Goof Off works great on gluey, rubbery stuff but doesn't even compare to Xenit on tar and cosmoline.
http://ecx.images-amazon.com/images/...500_AA300_.jpg
RWebb 11-12-2012 11:16 AM
ok, people - let's do a roundup on these products and run them thru a mass spec.
