Removing tar/asphalt from car.
Good news is they are repaving the streets in my neighborhood...
Bad news is a little uncured asphalt got splatted on my car... What is the best way to remove it without ruining the paint job on my car? Thanks in advance! SmileWavy |
Goof-Off
You can buy it in aerosol cans from Home Depot. Otherwise lots of places carry it in non-aerosol form. |
There are a number of products that will do it. Thinner will work but use it sparingly, as I'm always paranoid about the impact on paint. Goo-Gone and Goof-Off are both great products, I think Goo-Gone is what I have now and it's an organic base.
I agree with kaisen, Goof Off has worked well for me.
try wd40
WD-40 followed by water here.
i use WD40.
i walked on the beach in Houston once and got my feet covered with a tar substance. WD40 worked then..on a car it is an easy swipe with a soft crappy t-shirt scrap. |
Turtle Wax bug and tar remover has always been my go to for removing tar, and the soft rubber that smears on cars after track days.
Goof Off works well
Jet Fuel ( Really) it's just very good kerosene may not be as easy to obtain as goof off. |
I will check for goo off... have WD40 in the garage but prefer not to use solvent on paint job. Thanks! PS, Related story, I was installing a exhaust fan on the corrugated roof of a machine shop. I was sealing the flashing with cold tar (henry's), I slipped and grabbed the flashing (two story building) and smeared my arm with tar. I climbed down the ladder and the guys in the shop pointed at a 55 gal. barrel full of oil, I think they said it was diesel... I dunked my arm into it and the tar wiped right off. |
Diesel fuel.
Mineral turpentine followed by water
I used to work in a diesel repair shop, diesel fuel is an amazing cleaner/remover. Of course you stink and there's probably some negative health impact, but damn my hands were clean!
AC paving crews soak all their tools in diesel. i watched a man clean his hands with diesel and then eat a sandwich. brutal. i wonder if he is dead yet.
Prep Solv. Same thing happened with my truck. I went to my body shop guy and he came out with Prep Solv and a handful of rags. Wet rags and wipe till clean. Then apply a coat of wax. Prep Solv is what body shops use to remove wax and other crud before painting.
go buy some Tar/asphalt Remover from Meguiar's
oh yeah!
Clay bar works gor the smaller stuff.
| All times are GMT -8. The time now is 07:17 PM. |
