-   -   Attic insulation after pot light installation (http://forums.pelicanparts.com/off-topic-discussions/718963-attic-insulation-after-pot-light-installation.html)
look 171 11-24-2012 02:04 PM
I don't know what to tell you about that because we don't use those boxes. We use IC cans doesn't matter what's up there in the attic. Its not worth the few bucks in saving, plus, they are screwed to the joist so it will never come off. You might be able to remove the lights and snake your hand in there and peel off the tape. Better yet, leave the hole and remove the light and vacuum out the insulation after its all done. Since they are remodel cans, it can be remove with ease. You gotta let the heat our somehow.
wdfifteen 11-24-2012 02:26 PM
Originally Posted by HardDrive (Post 7111032)
I thought this was about something very, very different.
LOL! Me too.
Christien 11-24-2012 02:27 PM
I'm just going to build a box around them. Seems like the simplest and most fool-proof solution. A measuring tape, some drywall or styrofoam, a cutting knife and some adhesive and I'll have it done in less than an hour.
beepbeep 11-24-2012 02:31 PM
I assume insulation is mineral wool and as such, it's non-flamable
(otherwise, you couldn't have it on the attic ;) )
What's the wattage? I have 20W pots and they need less of a inch (19mm) free space above them to be "legal".
If using 10W, they don't need free space or pots.
I think you'll be all right.
juanbenae 11-24-2012 03:31 PM
Originally Posted by Christien (Post 7111061)
seal off the attic for good.
how are you gunna get the pot out of the attic when it ready?:confused:
look 171 11-24-2012 04:21 PM
I think he meant no one goes in there unless it is absolutely necessary.
Christien 11-24-2012 04:34 PM
Well, harvesting the pot would be absolutely necessary :) I think he was playing on the joke. Maybe we should call them cans, not pots...
look 171 11-24-2012 05:06 PM
siht, I completely missed that one.
DanielDudley 11-25-2012 04:41 AM
You need to be careful, as some lights are designed to work in insulation, and some are not. They do have thermal limiters now, but you have to make sure the ones you buy are the ones you need to use.
stealthn 11-25-2012 07:59 AM
Did you not get a permit? If not if anything happens your insurance won't cover anything.
1990C4S 11-25-2012 09:15 AM
A permit for pot lights?
Nostril Cheese 11-25-2012 09:55 AM
So did I.
stealthn 11-25-2012 10:53 AM
If they are new wiring, then yes. Code will also dictate what you can and can't enclose
Joeaksa 11-25-2012 01:23 PM
What? You do not smoke Can? :)
