-   -   Upgrade fluorescent to T8? (http://forums.pelicanparts.com/off-topic-discussions/722950-upgrade-fluorescent-t8.html)
Aggie93 12-09-2012 11:03 AM
I have a T12 ballast going bad. Is there any reason not to install a T8 ballast instead?
Neilk 12-09-2012 01:15 PM
Fwiw, I just had a bad ballast in 48" T8 fixture, it was cheaper to buy a slightly lesser fixture than a new ballast. Have you looked into a new fixture instead?
carambola 12-09-2012 01:37 PM
it is easy, but not a simple plug and play
rwest 12-09-2012 01:37 PM
T12 bulbs are on the way out and T8s are more energy efficient and produce more light. The sockets are the same, so I would do the conversion. Wiring is a bit different, but still simple, follow the schematic on the new ballast and you should be fine.
Rutager
porsche4life 12-09-2012 01:44 PM
Why not some sort of LED fixture? Less trouble, better light, and less energy use.
nota 12-09-2012 01:49 PM
LOT MORE UP FRONT COSTS SmileWavy
manbridge 74 12-09-2012 01:50 PM
Look the specs(amps, hertz, watts, etc.) listed on each ballast. They need to be the same or you get overheated ballasts which cause the light to blink off until ballast cools. Incorrect ballasts can also cause light not to turn on at all. Been awhile but I'm thinking you can't interchange.
porsche4life 12-09-2012 01:58 PM
<div class="pre-quote">
Quote de <strong>porsche4life</strong>
</div>
<div class="post-quote">
<div style="font-style:italic">Why not some sort of LED fixture? Less trouble, better light, and less energy use.</div>
</div>LOT MORE UP FRONT COSTS <img src="http://forums.pelicanparts.com/support/smileys/wavey.gif" border="0" alt="" title="Wavy" class="inlineimg">
But it all works out in the end. SmileWavy!
