What engine is this V8?
I have just moved out some tenants who owe me a few dollars. They have left this engine in the garage to cover their debt but I know jack shiit about V8s other than they have 8 cylinders. Our parting has been less than congenial, so I haven't been able to get any info from them about the engine.
So I am wondering what I have inherited here, and what is it worth. Keep in mind that this engine is in Australia and is most likely out of an Aussie V8 (GM or Ford), but I know there is a lot of engine-sharing between Aus and US models, so some of you may recognise it. http://forums.pelicanparts.com/uploa...1355753316.jpg http://forums.pelicanparts.com/uploa...1355753383.jpg http://forums.pelicanparts.com/uploa...1355753423.jpg http://forums.pelicanparts.com/uploa...1355753454.jpg http://forums.pelicanparts.com/uploa...1355753532.jpg |
looks like a GM LS motor to me.
LS1, 3, 7 not sure. |
I agree looks like a GM LS
Bill
That looks like a HSV engine. Probably from a Senator early 2000s. It's worth maybe $3 to 4 grand if it's not fuched. Not bad really. ;) Good luck with the sale. |
You have one hell of a score on your hands. It's either an GM ls1 or ls6- that oil pan alone is worth some serious grip.
If they left THAT behind must've been a significant debt. Wish it was closer, I'd buy it from you. rjp |
It's a 2004 LS1 from what we'd call the Pontiac GTO and what you'd call the Holden Monaro CV8
Certainly it is not stock anymore, and has been apart at least once Good luck! Its worth plenty even as individual pieces |
Nice engine. I'm looking to put one of those into an older Chevy truck.
This looks like it could be a serious piece. If they owed you money - consider it paid. If they didn't I would send them a nice xmas card
QUOTE=kaisen;7154598]It's a 2004 LS1 from what we'd call the Pontiac GTO and what you'd call the Holden Monaro CV8 Certainly it is not stock anymore, and has been apart at least once Good luck! Its worth plenty even as individual pieces[/QUOTE] |
That thing looks pretty clean.
Willing to bet it's a runner. Al the intakes/openings have been covered. Someone took the time to seal it up for a reason. That winch in the background looks like a beast. Might be worth a couple of bucks if it works. |
Thanks for the input guys. It looks like my $3K+ in lost rent and repair bills will be covered.
I'm curious about the sticker with barcode on the back of one of the heads. Also, I know we can decode Porsche engine numbers, but is there some formula for decoding GM numbers? |
You can get new LS1 crate motor for right around $3,000.
Although that motor may not be stock. Oil filter has been relocated which you typically do for a race application. Depending on what's been done it may be worth that or more. |
3MA is the GM build code for a 2004 Pontiac GTO LS1....roughly 345hp Casting number 12561168 is a LS6 or late LS1 aluminum block (both 5.7L) The 2004 Holden Monaro / Pontiac GTO, Chevy SSR, and the C5 Corvette were the last vehicles to use the LS1, both replaced by the 6.0L LS2 the following year The etched serial number won't tell you anything |
The real question is... Will that fit in my 944. ;)
It doesn't weigh any more than what's in there |
Nah! The REAL question is ... will it fit in my 911!
But you'll be much happier selling it for the money :D |
If the tenants were a bit dodgy, the engine probably is too.
You may wish to run the serial numbers by the police before you look at selling it. |
Atmost that is $1000. That oil pan is a few hundred. Being a 5.7 its a LS1. The short block is a $100. junkyard piece. The cylinder heads may be worth another $150. with rockers. Complete LS1s are very cheap running with harness and computer.
The winch may be a few hundred.
V-8 engine has 8 cylinders and shape like a V. There you go :D
| All times are GMT -8. The time now is 03:02 PM. |
