Profapi.dll Error? Virus or?
My parents have a Win 7 computer that on startup or trying to run most programs pops up a Profapi.dll error. Specifically it says it can't start because profapi.dll is missing.
Is there something I can download to fix this, or what is the plan of attack... I can't seem to find a clear answer in my usual fix via google approach... |
More than likely a WinAntivirus variant. Malwarebytes should get it. If you have issues updating malwarebytes, just try to get the latest version installed without updating, run it and see if it cleans stuff up. If so and the machine becomes stable, update and run it again. Ditch AVG and just install MSE. Nothing's perfect in the Windows environment, but it is as good as the pay programs today.
If your AV doesn't pick anything up, go start->Accessories->Command Prompt (right click, run as administrator) and type in sfc /scannow . It will check all the major DLL files to see if any are corrupted/messed up.
Super Moderator
Sound like it might have been corrupted. Windows Repair/Recovery should help.
Multiple attempts to run MWB and I keep getting the runtime error 53, file not found:mbamcore... Trying things I'm finding on the MWB forums....
It's malware. Don't bother with sfc.
still pounding my head against the desk... can't seem to get MWB to load...
Now getting an error writing to the registry key...
The joys of Windows.
![]() Google the error. Is it a RegSetValueEx error? |
yes... 5
Make Bruins Great Again
Apparently there is a malware that corrupts that dll.
Try using MWB Cameleon: http://downloads.malwarebytes.org/file/chameleon It works when the malware is blocking MWB. If you can't get to it from your machine you may need to download it from a clean machine and run it off a jump drive. As a rule, I always try to clean a machine while in Safe Mode.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
19 years and 17k posts...
Run this... follow the link, download to a thumb drive and follow the instructions carefully...
Norton Power Eraser | Free Tool |Easily remove scamware that traditional virus scanning can
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Chameleon wont work on this either....
NPE wont run the .exe because of the missing .DLL |
Pretty sure the dll is not actually missing. The malware is messing with the system.
If you have another Windows pc handy, you can take this drive and hook it up
To the other pc as a secondary drive and attempt to scan the drive from the other pc. It may pick up the right bits of the malware to corrupt it, then with the drive back in the original pc, you may have better luck with the removal programs. |
I've got another one handy....
More than likely, the malware stripped the "system" user permissions from various files. If "system" does not have rights to a file, it can't run it and since these files are crucial to Windows, Windows can't run right.
Worst case, you may have to do an "inplace install" of Win 7. It'll reset the permissions and leave most of the installed programs intact. After the install, you should be able to run scans and should.
Yep, do what Dave has suggested...
