T77911S's Avatar
bad head gasket on my jeep?
i have a 99 grand cherokee with an inline 6. there is oil seaping out between the head and block on the right side. time for a head gasket?
it never over heated but has 190k on it.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 12-31-2012, 10:33 AM
drunk and stupid
HHI944's Avatar
The head gasket can be bad without over heating.....sounds like it just gave up the ghost at the edge of a cylinder.........those old I6 are pushrod right? No messing with timing and the parts most likely quite cheap might as well do the other seals in the head and valve seals as well. ....still shouldn't be $100 in parts and a good saturday afternoon project
Old 12-31-2012, 10:54 AM
T77911S's Avatar
thats what i was thinking. machine work will be the big expense.
RACE CAR:: sold
Old 12-31-2012, 11:14 AM
Scott R's Avatar
Happens all the time on the 4.0, pull the head have it checked by a machine shop. They crack between cylinders 3 and 4 if they do. At the very least it will need to be decked. Think it was $80 for the gasket kit, $40 for new bolts and about $100 for the machining including two or three new valves.
Easy job really, lots of room to work.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
I knew somebody that had this on a older BMW ( 525i I think) but it was engine coolant. All it needed was a new head gasket.
Old 12-31-2012, 11:18 AM
Alot of the 4.0's do it. Doesn't affect the way they run or longevity. Just makes a mess.
Old 12-31-2012, 11:22 AM
Don Ro's Avatar
190k?
Meh, half life. Fix her up 'n go again.
I miss my '92 XJ.
Don
"Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence."
- - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View
Old 12-31-2012, 12:11 PM
99-02 4.0 cracks between 3 and 4. The older 4.0 you couldn't hurt. Not a tough or expensive repair.
Old 12-31-2012, 02:20 PM
