he should learn to count better..
cant believe he admitted that little tidbit. glad thing he doenst check the barrel is clear by staring down the muzzle. damn. |
Yup XDs are the same way.... You have to pull the trigger to release the slide. I triple check, and still find a safe direction to point mine before I pull the trigger. |
i think on a glock..(i have one, but my memory is waning) you have to have the firing pin/hammer dropped prior to disassembly right? so you actually need to dry-fire it? i'm new to glocks. i still need to run the drill a few more times.
any gun, i need a visually clear chamber. |
Yes, you have to dry fire it before removing the slide. Still no excuse whatsoever for not clearing the gun before you get that far. None. And even if you didn't, you should still have muzzle discipline. But then if you're already so careless as to not clear the gun, well....
I'm still trying to figure out how you shoot yourself in the hand. On the bright side, I suppose he's lucky he wasn't firing hollow points. The wound to his hand looks relatively superficial.
So, What pistol did he ND with?
I think it said it was a Kimber
dumbass. if the slide isn't back and you haven't chamber checked with your pinky. IT'S LOADED!
<iframe width="640" height="360" src="http://www.youtube.com/embed/TNNvjbzrC0Q?feature=player_detailpage" frameborder="0" allowfullscreen></iframe>
I'm sure you guys have all seen this one . Caution , he drops the f bomb.
<iframe width="560" height="315" src="http://www.youtube.com/embed/uI7G2rmF-go" frameborder="0" allowfullscreen></iframe> |
"After the shot went off, my training took over: I called my parents ..."
ROTFLOL!!! G |
| All times are GMT -8. The time now is 08:36 AM. |
