JW Apostate
Yes!
That way you qualify for the 20 year warranty with James Hardie. KT
'74 914-6 2.6 SS #746 '01 Boxster |
Now in 993 land ...
Reviving an old thread here. Lots of good information. I have a bathroom VERY much like the OP. Hallway bathroom. Raised foundation plywood floor from the 70s. It currently has laminate floor (poor choice put in by PO at time of sale). I put down laminate in the hallway and most of the rest of the house.
It looks like I have a good set of instructions here from the best, but my main worry is the stack height of the tile and hardibacker exceeding the hallway significantly. With a door, I can't do any of this wedging tricks seen above. How can I check this without ripping up the existing floor? I want to plan this out carefully ... My plan is to pull out the vanity and toilet, tile all of that, and then install a new vanity and re-install the toilet (if it still meets my wife's spec, not fitting the vanity). The tub will stay, it is pretty decent, aside from the 80s color. New shower door will be all it needs. I have only laid tile once in my life helping a friend. I think I can handle it. And if it doesn't come out perfect, that's fine - I never use that bathroom. Only the kids and guests! ![]() G |
All of my tile floors are level with my 3/4" hardwood, but I still use stained hardwood door thresholds. A couple of areas aren't level...fireplace, etc.....a good flooring supply place will have ones that accomodate height differences.
Now in 993 land ...
I was able to get a view at the stack in the floor heater/ac vent!
1" thickness on top of the subfloor, made up by particle board, foam moisture barrier and laminate floor. I guess 1" should be plenty to put the HardieBacker down and tile on top, coming out level with the hallway! Right? Thanks! G |
Now in 993 land ...
So, what type of tile is easy to lay for a novice? I laid some at a friends house (kitchen), but we drank a lot of beer and it wasn't my house.
I already learned above that marble is out. I would think a fairly large size would be good, and also contemporary. Something that doesn't show the dirt and is easy to clean. Thanks! G |
JW Apostate
hardiebacker installed directly over the subfloor is the best method if you do not need additional thickness to transition to an existing adjoining floor elevation.
Most tiles floors over hardiebacker finish at .75" above subfloor, which is perfect for transitions to hardwood or carpet.
Driver
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa Last edited by Noah930; 02-09-2018 at 04:51 PM.. |
Platinum Member
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Now in 993 land ...
Ok, I got going with my work a long time later ... and followed the advice here. I have the hardibacker down but need to flatten the floor out more. I already did a little with more thinset on the low spots under the hardibacker but it was pretty extreme. There is one floor joist running the lenght of the room. And the side where the tub is on has sagged with time (almost 50 year old house). So, I'll go back with some leveler, and massage that side of the room. Of course the other side of the joist sags too, but less, so I am targeting flat, not level.
At any rate, once I have the prep work done, I can't wait to put down some tile. The room is only 5x10. Question: For a beginner, do you recommend smaller or larger tile? My assessment: Smaller tile pro: Easier to cut and lay around nooks and crannies. Less important to have perfectly flat base. (?) Smaller tile con: Lots of pieces, more grout, more pieces to align and keep in a straight line. Larger tile pro: Less pieces, faster (?) Larger tile con: Harder to cut for nooks and crannies, not so good over non perfectly flat base. I found a nice 6x12 and same in 12x24. Don't like the idea of squares (4 corners meeting up, and not sure about overlapping them by 1/2?) Thanks! G Last edited by aigel; 08-12-2018 at 10:24 PM.. |
Go smaller; doesn’t really take much longer and the floor irregularities won’t be as pronounced.
Big tiles in a small area might look odd as well. Big tiles are actually harder to install as if you get voids under them while you’re trying to get the heights matched up they will crack later.
Rutager West 1977 911S Targa Chocolate Brown |
I actually laid out the tiles covering the whole kitchen area three different ways before deciding...mebbe mix the two different sizes....seems ready for being staggered with no cuts! Have you considered diagonal runs
?Oh yeah...all my floors after the Hardi is down are flat....good luck! Don't have the tile grout line running directly over where you have the Hardi seam if avoidable. Smaller tiles...much easier to work with.... |
Now in 993 land ...
Diagonal! Haha!
![]() I brought the floor 1/4 inch up already on the low spots with the hardibacker. There is another 1/4 inch to go. I did not want to do it all with thinset under the hardibacker, as I read that it has its limitations on how thick you can put it on there due to shrinkage. We will see how it goes. Reading more, people claim that larger tile makes a smaller room look lager. I don't know. 6x12 isn't exactly small. Maybe some more of you chime in. I like the idea of 6x12 and going slow, so I can always jackhammer the last section if I have a bunch of lippage. How wide should I plan my grout? I read wider is better for the idiot DIYer. G |
Yours is about the same size as my first project years ago...12x12 w/ 1/4" spacers (bought a pack of rubber/plastic thingys)....just a personal thing, but that looks right for my area...
I despise grouting with a passion....KT is da man !
Now in 993 land ...
This definitely will never be my favorite activity, I can already tell, if nothing else, because you are on the ground! Specifically, if you mess up, it seems it isn't easy going back unless you love to drive a Hilti. I'll take my time. It will be a few weeks before vanities show up. And then I get to do it again in the master bedroom, by then I should be better.
If there are no other inputs, I'll go with the 12x6, the more I read, the more it sounds like it is easier to put it down without lippage and over a non-perfect base. G Last edited by aigel; 08-13-2018 at 05:00 PM.. |
Now in 993 land ...
Done
So, the floor definitely was the biggest PITA of the project, manly because it wasn't flat. I used leveling compound to do the rest, worked like a charm, but of course you have to come up with a way to seal the edges so it doesn't run into the walls etc.
The biggest flatness problem in the end were the fiberglass tape connections between the hardibacker boards. I sanded them flat all the way where I'd get into the tape but these were still not even with the rest of the floor. I had to pay good attention to not get any lippage around these areas. Happy to report that after grout I was able to slide a 5 gallon bucket across the entire floor without it hanging up anywhere. The 1/16" grout helped. In the image the floor has a lot of contrast. In real life it is a lot less pronounced, more like a marble. I wanted something that doesn't show dirt easily, and that certainly was accomplished. There were no floor board tiles with this tile set, so I went with wood. Next time I think I'll want to go with tile and will stay away from floors that don't come with floor board pieces. So, after this I'm taking a couple months break and then dig into the master bedroom. I bought the same vanity and tiles to make it a match. Thanks for all the great input everyone. And yes, the stack height was perfect to mate with the hallway laminate. G
Looks fantastic, nice work.
