Replace coil springs on garage door, Should I do it myself?
One coil spring broke, the garage door won't open. Should I do it myself? Looks like a lot of tension.
Only if you like getting your ass kicked by a big spring.....
Being asked by the safety technician? ;)
I've seen it done by a pro at my house and although I'm recklessly self assured at times, I'd never try it myself. Way too much kinetic energy up there just waiting to remove an errant finger! Leave it to a guy who does it everyday. I'm assuming it's a coiled spring around a shaft at the top of a roll up door. |
what type of spring system do you have?
after you know this then look on Youtube for videos on how to replace the spring you have. It can be dangerous but if you have the right tools/ and have watched the videos, then you should be able to fix the system you have |
Done four (torsional spring around the shaft) with a helper - can be very dangerous if you lose control before securing the hub on the shaft. This is one of those things - if you have to ask about doing it - engage a professional.
Considering your profession, you know the answer.
Look on Craigslist in the services section. Don't know about where you are but here in Phoenix, lots of guys who used to work for big garage door companies have gone out on their own. Since they have virtually no overhead the prices are very reasonable.
Measure your spring and buy it online and it is 1/10th what the local price is.
Buy a 3 foot rod and saw it in half and it works great. Do a search on the number of turns to tighten. |
Totally! DIY! :D
Honestly tough... if you're careful, its no biggie. But when things go wrong, they have a tendency to go REALLY wrong. |
I've watched it done at my house by a pro. Yeah, it looked like I could DIY it. But for $150, I'm not gonna take that risk. I do stupid and dangerous things that are fun. This didn't look like fun.
Don't. Leave it to the pro's. I've got a friend who got all tangled up in one, almost killed him.
One arm mangled. |
Listen to Rick (post #10). If you think it will be fun, go ahead and try it. I watched it done. It doesn't look hard but the potential for disaster is high. It didn't look like fun to me.
NO... Call a po and get it fixed. It's not what I would call DIY.
But if you're a stubborn SOB like me then proceed with caution. I recently installed an auto opener on mine. All went well but I've fixed them before. To replace a spring you need to fully unwind the door before releasing the two U bolts. Not an easy task on your own. BTW, My BIL told me his uncle lost a thumb trying to fix his. My motor install thread. http://forums.pelicanparts.com/off-topic-discussions/703073-garage-door-opener.html |
It was cheap to have the door company come out, something like $120 total.
Jim |
A friend of mine has a nice scar that starts under one eye, crosses the bridge if his nose and ends on the opposite cheekbone.
He received this beauty mark by tensioning his overhead door springs. |
I hired a pro to do mine. He replaced the spring, and left me a can of garage door lube. The entire door is a lot quieter now. The spring let go in the middle of the night while we were sleeping. It was a LOUD bang and we looked all over the house trying to figure what the heck made the noise. I found out when I tried to go to work.
I suspect the other door will go fairly soon. It does not get quite as much use. |
No. I've done it in the past when I did renovation and remodeling work. When one of mine broke at my house, I called out a pro who fixed it for all of $100 or so. It's straightforward, but the potential for bad things to happen is there.
Hi Hugh!
I replaced the stretchy springs on my one car garage door, but I surely would hesitate to try DIY on those twisty kind. Yikes! Scary! |
If nothing else, just go online and see what it takes, (plenty of info on the googles) then consider the risk/ reward.
Sure, you could do it. Do you want to? Wouldn't you rather shoot rattlesnakes? |
Hugh,
Went through this last year, thought I could do it myself and read smeo forums and decided to call a guy in. He was done in 15 minutes and I could tell how much "power" was loaded in that spring. For myself and my family I made the right choice just to call a pro. Bob |
I replace torsion springs on my rental properties on a regular basis. I use two 18" sticks of rebar rod with last 1 1/2" ground to a slightly smaller diameter. One person uses the two sticks to tighten the spring. A second person tightens the set screw. It is not hard. It just takes patience and care. I would never do this job by myself, though.
Jurgen |
Hugh,
I would not recommend attempting this job as a DIY project. The springs have an incredible amount of tension on them (i.e. a good way to a serious injury). To remove the spring you have to unwind the unbroken one and remove both cable drums. If the cable drums are not reset properly the door will now be crooked in the tracks. Also if you just buy a replacement for the broken spring, the unbroken one may break while it is being rewound. I always suggest to customers that they replace both springs at the same time, unless the other has been replaced within a couple of years. This job is best left to a professional as the spring tension equals the doors weight. It can be done in under an hour by a competent door repairman. That is both springs, check of the door operation, and a lube. P.S. I know lots of professionals who have been badly injured by springs, so I would not risk your career on saving a few bucks and winding up permanently mangled. |
I've done this on trailer and garage doors, and several times have nearly crushed my fingers or had a rod spun into the face.
Not a recommended or safe DIY. |
I'm surprised to read so many DIY guys so concerned about this task. I guess since I live on an island, the costs of getting a pro do do this job would be probably more in the range of $750 ( which creates an incentive to DIY). I've had to do it on a couple of homes and it's a job that if you take your time and are prepared, it's no big deal. Don't get me wrong most of the time if a new door is going in, the vendor will offer a good installation price and I'm happy to off load the task. Probably if it was available to me for $120, I might think about it. Cheers
$120 would not get it done here. That would be about the service call fee, now add parts and labor. |
This is a very, very easy job for an even remotely skilled DIY'er.
Should your average Joe, who has never changed his own oil or done any DIY past replacing a light bulb do it? No, probably not. But we are on a car enthusiasts forum, and most of us here are experienced in automotive and other DIY. The key is to be able to follow very basic directions, and have a couple of basic proper tools. You also need to have a basic understanding of how the spring system functions, but that's not complicated. There are a ton of instructional videos on Youtube, as well as webpages. For the tools, the only thing you really need are PROPERLY sized turning bars. They just need to fix well in the turning cones, and be near the right length. You'll see that the springs are under tension, of course, but it doesn't take a lot of strength to turn them. They also lose tension very quickly, after not many turns. The process of winding and unwinding the springs is the only part of the process that has any danger, but it's really a matter of just having the right fit and being careful. You will be turning the cones using two bars at the same time (obviously, one to hold tension, the other to turn it more). The danger is that one of the bars slips out of the cone (or less likely, out of your hand). The spring can then turn, and with the other bar still in it will turn very quickly and forcefully, if it whacks any part of your body, yeah, that's not going to be good. Adjusting the cables is very easy, pretty much foolproof for any decent DIYer. Automotive jobs, IMO, are far, far more dangerous and complicated. I think jacking up, stablizing and working under a car is more dangerous. Replacing coil springs is more dangerous. As far as technically complicated, I'd rate this about the same level as replacing brake pads. That's my opinion after having done many of these over the past 20 years. |
A friend broke his arm attempting this.
I think a key question that hasn't been asked is: Is the Porsche 'in' the garage or 'out'?
If 'in' and you can't get the door open, I'd call a pro. If 'out' and there's no other cars 'in' then I'd do it with a friend. I've done it with a friend when his door had a cable problem. If you're cognizant of the dangers involved and take the necessary precautions it's not that hard. Being aware of the danger is half the battle. Doing it safely isn't that difficult, but I recommend you do it with someone else helping. |
Almost 300,000 are injured taking a bath or using the toilet each year.
300 people DIE every year trying to take a bath in the US alone. |
This actually seems uniquely like a one person job. You certainly DON'T want two people doing the winding or unwinding of the springs. That would be a recipe for disaster. |
I've done it myself........Use the two rods as mentioned above and take your time.......I was younger and poorer when I did it, probably hire it out now. Depends on the cost and your budget.
Having moved billion dollar satellites together as part of a team it wasn't hard to do this job as well. |
I did it myself, just watched the video from the online spring seller. I didn't think it was particularly dangerous until I read all the stuff on here.
You can buy the bars of the correct diameter at Lowe's or Home Depot, wrap the ends in tape so they fit snugly. The instructions tell you how many turns to go. I think if you can rebuild an Aston motor you can probably handle garage door springs. |
We have an HOA with a privacy gate. I think I'll call the guy that services it to do the job. Besides, at the moment, I don't really have anyone that I can get me to assist in this. Thanks for the input.
You do not need assistance to do this and the only tip I have is to use a large pipe wrench to get the springs off the cones. |
I have done lots. Replacements, adjusting, etc. I can't believe how many people here are saying 'don't do it'. Get a proper pry bar and position your body to hold the load, it's not a huge force on the end of an 18" bar.
I know someone who died in a car crash. I still drive to work every day. I wear my seat belt and take appropriate precautions. It's not rocket science. And, IMO, it's not more dangerous than working under a car. |
rickl, there's what...100 lbs of force on a bar when tightening the torsion spring? If a 1/2" rebar rod bends or breaks, I've got big problems. Done dozens of springs with the same homemade bars. I really don't see the need to fix what ain't broken. That said, buying new, yeah, I might spring for the rolled steel at Home Cheapo, but if I have rebar laying around, I wouldn't hesitate to use it. |
The only person I know that damaged anything was using socket extensions that fit in the holes to tighten the spring. |
