-   -   iPad question... (http://forums.pelicanparts.com/off-topic-discussions/730801-ipad-question.html)
Dottore 01-26-2013 11:39 AM
iPad question...
....anyone know how to disable the "auto-rotate" feature on the screen?
motion 01-26-2013 11:40 AM
Slide the lock button on the side.
Neilk 01-26-2013 12:06 PM
Or put 4 fingers on the screen and move them up the screen so you see the brightness adjustment. Slide left and touch the lock. That will also lock the screen
masraum 01-26-2013 12:11 PM
Instead of using four fingers, you can also double click the button.
Dottore 01-26-2013 02:45 PM
None of these tips seem to work. I'm using a first generation iPad. Does that make a difference??
craigster59 01-26-2013 02:54 PM
Try one of these, beat it at it's own game....
http://forums.pelicanparts.com/uploa...1359240883.jpg
masraum 01-26-2013 02:59 PM
Can't you also disable it from within settings?
Dottore 01-26-2013 03:02 PM
iPad. No. Can't find any settings to disable.
masraum 01-26-2013 03:04 PM
And if you double click the button, does a new little thing pop up on the bottom of the screen?
Dottore 01-26-2013 03:09 PM
well if I double click the round button, the apps/icons appear at the bottom of the screen.
craigster59 01-26-2013 03:21 PM
Go to settings, general, use side switch to lock rotation.
masraum 01-26-2013 03:29 PM
And once that apps/icons section pops up, you should be able to slide it over until you see some settings. I believe one of those settings is to lock the orientation.
Here, instructions complete with pictures.
iPad: Understanding the side switch
craigster59 01-26-2013 03:37 PM
That's the problem, his side switch is being used to mute not lock rotation. He just needs to change it. I don't think you can use it to do both symoltaineeyuslee.
masraum 01-26-2013 04:00 PM
Yep, and my link covers that with pics.
craigster59 01-26-2013 04:09 PM
So is there the shortcuts posted before with the 2nd Gen? I've been thinking of getting one.
gprsh924 01-26-2013 04:27 PM
Double tap home button. Swipe the right. In the left corner the is a box with a circular arrow. Click it and rotation will lock.
Dottore 01-26-2013 05:10 PM
Finally got it. You live you learn.
Many thanks for your help guys.
