iPad question...
....anyone know how to disable the "auto-rotate" feature on the screen?
_____________________ These are my principles. If you don't like them, I have others.—Groucho Marx |
Slide the lock button on the side.
'95 993 C4 Cabriolet Bunch of motorcycles |
Or put 4 fingers on the screen and move them up the screen so you see the brightness adjustment. Slide left and touch the lock. That will also lock the screen
Instead of using four fingers, you can also double click the button.
None of these tips seem to work. I'm using a first generation iPad. Does that make a difference??
_____________________ These are my principles. If you don't like them, I have others.—Groucho Marx Last edited by Dottore; 01-26-2013 at 03:03 PM.. |
Try one of these, beat it at it's own game....
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain |
Can't you also disable it from within settings?
iPad. No. Can't find any settings to disable.
And if you double click the button, does a new little thing pop up on the bottom of the screen?
well if I double click the round button, the apps/icons appear at the bottom of the screen.
Go to settings, general, use side switch to lock rotation.
Here, instructions complete with pictures. iPad: Understanding the side switch
That's the problem, his side switch is being used to mute not lock rotation. He just needs to change it. I don't think you can use it to do both symoltaineeyuslee.
Yep, and my link covers that with pics.
So is there the shortcuts posted before with the 2nd Gen? I've been thinking of getting one.
Double tap home button. Swipe the right. In the left corner the is a box with a circular arrow. Click it and rotation will lock.
Garrett Living and Thriving |
Finally got it. You live you learn.
Many thanks for your help guys.
