Targa, Panamera Turbo
There is Nothing More Disgusting Than Wasting Energy...
Well actually I can think of about 48 other things that are more disgusting but what gets me pissed is to think that we are still flaring off nat gas. While the fracing production process has become so effective it has driven down the price of nat gas making it a product we can waste due to the economics.
Its just amazing IMO
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
another round please
Yea, I'm pissed off seeing the burning off too. But the fracking, not fracing, is needed for our economy. It's probaly 1/tenth of a billion, per quintenthquadrillionth of 1/100/tenth of 1% of all the gas in this world we will ever use. Have a great warm day.
Getting old is not for wimps. |
don't get it..... isn't it 5% globally? could be wrong but I read that somewhere.
76' 911s Signature Edition |
Why do they have those flames at the wells?
Called flaring - got to do sump'n with it...if it flows its not good to stick around. Flammability issues and what have you.
BTW - I like fracing, just submitting my 4th book and guess what the topic is? Yup, hydraulic fracturing
AutoBahned
when I wuz growin' up half of Baton Rouge was illuminated by light from the NG being flared off at the refineries
yes, it is wasteful |
I used to think Fracking was a good idea, until it was in my back yard.
No left turn un stoned |
We produce hydrogen and oxygen from water (radiolysis) here and blow it out a stack. Maybe we should capture that.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Bollweevil
The Cline shell formation in N. Central TX is just beginning to start up and this formation is supposed to contain much more oil and gas than Bakken or Eagle Ford. That area (from west of Abilene to the Permian Basin (Odessa - famous or infamous for "Friday Night Lights") has already seen more than it's share of oil booms and busts. The difference this time: where are they going to get the massive amounts of water required by fracking? That area (and most of TX) is well into our second year of historic drought conditions and even in the best of times water is always a big issue in S, W and N TX. This issue is not only protecting what little ground water there is from getting polluted - it may come to do you use your water to frack or to drink ??
Jack 74 911 Coupe 2.7L - K21 Option - S suspension |
Kantry Member
I suspect we will indeed end up capturing and using the gasses now being flared.
Don't forget; in the early days of the petrochemical industry in Pennsylvania one of the by-products (gasoline)was dumped into the creeks because there wasn't a use for it. We'll get there. Les
Best Les My train of thought has been replaced by a bumper car. |
UnRegistered User
I thought there was an international moratorium to reduce flare gas emissions?
In some environmentally sensitive off shore platforms I had been on the flare gas was re injected into the ground until a market was found and a liquefaction plant was completed.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Unregistered
I'm not going to comment about flaring NG at remote wells, but in oil refineries flares are not burned just to get rid of unwanted gas. they are safety features used to help control the processes.
All vessels, tanks, and piping in a refinery is rated for a a maximum pressure and protected by relief valves. When a pressure gets too high the relief valve lifts and sends the product to flare. Understand that a typical oil refinery has a mind-boggling complexity that can't really be comprehended until you've worked inside one for a while. Hundreds of miles of piping, hundreds of thousands of valves. All refineries would recover all that gas and use it to fire their heaters and boilers, if they could. But that is not easy to do. In Southern California it is illegal to flare under most circumstances. If a refinery here flares off gasses it gets hit with a really big fine. Really big. There are some exceptions but even they usually include a FEE. The process required to capture all excess gasses to keep them out of the flare during process upsets (like a power outage for example) is very complex and expensive which increases the cost to refine, which eventually hits the consumer at least a little. The capability to recover all that gas does not exist in many places but eventually they'll all be required to upgrade to do it (or close down if they can't afford to do it). Here's a pic of the 5 liquid ring compressors we installed several years ago as part of a flare gas recovery project that I was the lead mechanical engineer on (the compressors cost a half mil each, this part of the project cost around $40 mil IIRC).
What is the big flame I see on the west side of the 405 around the Torrance area? I always assumed it was the safety measure you described.
Functionista
When visiting people, if waste comes up as a topic, I tell everyone I'm the greenest guy you'll ever meet as I make the extra effort to piss in their sinks.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
abides.
We are working on something to utilize gas that is normally flared off from wells. It's not all that simple... the gas is dirty and the supply is not necessarily steady.
Graham 1984 Carrera Targa |
Ubi bene ibi patria
Cheers JB
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke "As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras |
Unregistered
Their flare should not be going off $$$$$$$$. If anyone wants to read the SCAQMD rule 1118 on industrial flaring, here's the link although I bet no one gets past page 4 before being bored to tears: http://www.aqmd.gov/rules/reg/reg11/r1118.pdf |
haven't got'n your check yet huh? Funny thing, of all the folks I interviewed for my book, all the ones that were opposed to fracing do not get a royality check. I have not met a single sould who gets a check and complains that fracing is a bad idea....imagine that...
