| JW Apostate Join Date: May 2004 Location: Napa, Ca
			If this is a DIY tile job, 18x18 over concrete is a pretty difficult install. KT
				__________________ '74 914-6 2.6 SS #746 '01 Boxster | ||
|  03-29-2013, 08:34 AM |
| Just thinking out loud Join Date: Nov 2001 Location: Close by
			No it's not.  It might be labor intensive, but it's not difficult.  Prep the surface, lay out your tile, starting in the center of the room, arrange the tile how you want it, ie. square, diamond or what not, then work off of it.  Don't call me when it comes to grouting. A good set of knee pads is a must.
				__________________ 83 944 91 FJ80 84 Ram Charger (now gone) | ||
|  03-29-2013, 08:53 AM |
			If your surface is wood, given your climate, you might consider putting down a vapor barrier.
				__________________ 83 944 91 FJ80 84 Ram Charger (now gone) Last edited by mattdavis11; 03-29-2013 at 09:17 AM.. | ||
|  03-29-2013, 08:55 AM |
| Registered Join Date: Jan 2002 Location: Long Beach CA, the sewer by the sea.
|  03-29-2013, 09:01 AM |
			right, don't know what I was thinking.  Between all the concrete and wood, vinyl, linoleum, I lost focus.
|  03-29-2013, 09:11 AM |
| Platinum Member Join Date: Jul 2001 Location: Leave the gun. Take the cannoli.
				 | Quote:
 OP - Lots of 'interesting' advice in this thread, think about it, and do it right. Trekkor - scrape the old floor up, check for humps with a straightedge, perhaps a leveling compound... why the Hardiebacker over a concrete floor? | ||
|  03-29-2013, 09:43 AM |
| Registered Join Date: Aug 2004 Location: Baton Rouge
			thanks guys, concrete floors
|  03-29-2013, 10:43 AM |
| Registered Join Date: Nov 2005 Location: CA
			I say depend on what result do you expect. If expecting an ok result, that is it very hard, but if expecting a perfect/beautiful tiles job, it's can be very hard. I know someone who cares every single gaps between tiles, in fact no gap at all. It has to be perfectly leveled everywhere, knocking every tile with a coin after done, and more. To get to that level, the bigger tha tile, the harder it get. Quote:
				__________________ Fat butt 911, 1987 | ||
|  03-29-2013, 02:19 PM |
			To prevent tile crack, maybe? I am thinking about hardi board or maybe kerdi ditra  Quote:
|  03-29-2013, 02:25 PM |
			I was responding to another post regarding the Hardiebacker. Over concrete, scrape all the old adhesive off. Cover any cracks with an isolation membrane. I will never use Ditra. KT
|  03-29-2013, 06:40 PM |
			For 18x18 you should have less than 1/16 of surface deflection in 4 ft. I use Level Quik self leveling underlayment from Custom exclusively. LevelQuik® RS (Rapid Setting) Self-Leveling Underlayment | Custom Building Products KT
|  03-29-2013, 06:46 PM |
| Registered Join Date: Jul 2008 Location: New Jersey
My appologies. I rushed my reponse and missed read the OP. Hardi backer isnt needed in this application due to concrete floors. I agree scrape up the vinyl check for level. thinset new tiles down.
|  03-29-2013, 07:04 PM |
			trekkor,  I was thinking that I will use ditra on my next floor tiles on concrete, but if you don't like it, there must be a reason that you can see. Can you go into a little more detail? And can you recommend some kinds of isolation membrane?
				__________________ Fat butt 911, 1987 Last edited by rnln; 04-15-2013 at 09:03 AM.. | ||
|  04-15-2013, 09:00 AM |
