-   -   Position of speed and reference sensor connectors - 3.2 Carrera (http://forums.pelicanparts.com/off-topic-discussions/744878-position-speed-reference-sensor-connectors-3-2-carrera.html)
BGCarrera32 04-15-2013 10:57 PM
Rebuilt my engine...need to know the correct location for the speed and reference sensor connectors when placed in the vertical bracket on the driver's side of the engine near the intake. Top connector (white) is the the head temp sensor, the other 2 connectors are marked BG and DG but unfortunately my BG and DG tags got removed from the sensor wires completely. I know which lines in the car harness plug into the middle and bottom connectors, but need to know if the middle connector in the bracket should be BG or DG.
Would like someone with a Carrera and the labels in tact to have a look please...
Thanks in advance.
enzo1 04-15-2013 11:14 PM
if you get no response, post here.... Porsche 911 Technical Forum - Pelican Parts Technical BBS
Nostril Cheese 04-16-2013 02:50 AM
If you have the wiring diagrams, you can pull the DME harness connector out and check for continuity. Mine doesnt have the tags either. Sorry.
BGCarrera32 04-16-2013 08:02 AM
Ugghhh...sorry...its called posting after midnight. Mods, please move...
rusnak 04-16-2013 08:26 AM
The position does not matter, so long as you get the two cables matched. You'll know if you don't because the car won't run.
shinrai 04-16-2013 08:45 AM
'87 carrera:
http://forums.pelicanparts.com/uploa...1366127063.jpg
rusnak 04-16-2013 08:47 AM
In that pic, the top is the reference (position) sensor, and the lower is speed. You can just make the middle plug reference, and the bottom plug speed. The top is CHT.
