Certified Pre-Owned
BGCarrera32's Avatar
Position of speed and reference sensor connectors - 3.2 Carrera
Rebuilt my engine...need to know the correct location for the speed and reference sensor connectors when placed in the vertical bracket on the driver's side of the engine near the intake. Top connector (white) is the the head temp sensor, the other 2 connectors are marked BG and DG but unfortunately my BG and DG tags got removed from the sensor wires completely. I know which lines in the car harness plug into the middle and bottom connectors, but need to know if the middle connector in the bracket should be BG or DG.
Would like someone with a Carrera and the labels in tact to have a look please...
Thanks in advance.
'84 Carrera Coupe
Old 04-15-2013, 10:57 PM
enzo1's Avatar
if you get no response, post here.... Porsche 911 Technical Forum - Pelican Parts Technical BBS
76' 911s Signature Edition
Old 04-15-2013, 11:14 PM
Hell Belcho
Nostril Cheese's Avatar
If you have the wiring diagrams, you can pull the DME harness connector out and check for continuity. Mine doesnt have the tags either. Sorry.
Old 04-16-2013, 02:50 AM
Certified Pre-Owned
Ugghhh...sorry...its called posting after midnight. Mods, please move...
'84 Carrera Coupe
Old 04-16-2013, 08:02 AM
The position does not matter, so long as you get the two cables matched. You'll know if you don't because the car won't run.
Old 04-16-2013, 08:26 AM
shinrai's Avatar
'87 carrera:
'87 911 GP White "casper"
'79 930 Copper Brown Metallic "beast"
'93 968 Amazon Green Met "moby"
'97 Esprit V8 "flat eric"
'97 993 Speed Yellow "tbd"
Old 04-16-2013, 08:45 AM
In that pic, the top is the reference (position) sensor, and the lower is speed. You can just make the middle plug reference, and the bottom plug speed. The top is CHT.
Old 04-16-2013, 08:47 AM
