Regenerated User
72doug2,2S's Avatar
Note for cattails.
"Application timing is critical for cattail control and differs between diquat and glyphosate products. The contact herbicide diquat can be applied any time the cattails are green and actively growing. Most owners using diquat products apply in the summer. Glyphosate products have a narrower window for optimum results. These products should be applied just after the seed head has formed. Energy reserves are at their lowest in the roots and the plant begins to store food in the roots in anticipation of next year�s growth. This food is produced in the leaves and transported to the roots. The application of glyphosate at this time results in its transport to the roots as well, thereby killing the root system. "
Cattail Management
My uncle has a country place, that no one knows about. He said it used to be a farm, before the motor law.
'72 911T 2,2S motor
'76 BMW 2002
Old 05-01-2013, 05:46 PM
This is a pic I posted recently of my largest pond, and it's been a healthy eco-system for longer than I've been alive. Spring fed (output is equilavent to a couple of water hoses on full blast) and full of life. Unfortunately, someone caught (and hopefully ate, since they were probably migrant workers) the bigger bass (10 lbs +), quite a few years ago. There is simply no way I would introduce chemicals...YMMV. When this pic was taken, the overflow pipes were clogged...unclogged, and now most of that crap on top is gone (flushed through the overflow pipes). This is my little slice of "heaven"
Old 05-02-2013, 03:34 AM
Regenerated User
72doug2,2S's Avatar
You have some good shade and wind protection with that tree line. Some water lilies might help control your algae issue though. An algae die off, which happens over night, can deplete the pond of oxygen. Your spring might mitigate the damage of an algae die off.
Algae die offs can literary kill the fish.
'72 911T 2,2S motor
'76 BMW 2002
Old 05-02-2013, 05:33 AM
Originally Posted by 72doug2,2S View Post
...Algae die offs can literary kill the fish.
My first rule-of-thumb is "do no harm"...hence I tread lightly on anything that might upset a balance that's been intact for decades. The algae isn't really an issue for me, though that pic shows it at it's worst...the real weed growth is underwater. I've seen more than my share of "fish kills" due to oxygen issues in other bodies of water over the years. I just don't take that risk...
Old 05-02-2013, 06:02 AM
Functionista
manbridge 74's Avatar
If you don't like chemicals (many chemicals in there already by the way) put an aerator in the middle to supply more 02.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 05-02-2013, 07:29 AM
Out of curiosity, why do you think my pond needs more O2? It's as healthy as can be imo...just needs a few grass carp . Probably aren't any significant amount of chemicals in there either, other than those found in the aquifer...no fertilizer run-offs, etc. reach this one. I would drink from that spring if the pond was drained. Sorry for the hijack...
ps: Judging from the arrowheads found in the surrounding area (many dating back 4-6000 years)...I suspect the Native Americans did too
Old 05-02-2013, 08:27 AM
Functionista
Walk across the bottom at the shallow end. Smell anything? The algae and bacteria strip away the 02 leaving smelly hydrogen, sulfides, and nitrates/nitrites (chemicals).
An aerator would cut down on the (from the pic I'm guessing) floating algae. You can even find solar powered ones.
Good water is all about balancing. Man can either make it better or worse. Almost all ponds can be improved.
Jeff
74 911, #3
Old 05-02-2013, 08:47 AM
Thanks Manbridge! I must admit it's probably been 40 years since I've walked in the shallow end, so I have no firsthand experience as of late . I've never even caught the faintest whif of what you describe (and I am familiar with the smell) when the dogs get in an stir things up though. Not arguing with ya...I might actually accidently learn something! BTW, I dare say that 75% of that floating algae is now gone...it accumulated when the overflow pipes were clogged. Wind shifted in the proper direction, pushed it towards the yonder end and algae was shooting through the overflow pipes like crazy for a few days as the water level dropped down about 6 inches to it's normal level.
Old 05-02-2013, 08:59 AM
Unregistered
sammyg2's Avatar
Carl Spackler: This place got a pool?
Ty Webb: Pool and a pond... Pond be good for you.
Old 05-02-2013, 10:26 AM
AutoBahned
RWebb's Avatar
healthy is hard to judge sometimes
ponds go thru a natural process of "aging" or succession - a clear alpine lake would be at one end (little or no life) and a swamp near the other end; eventually, the all ponds fill in with debris and become land
I agree with manbridge tho - check the shallows, even snorkel in the deep end and see what is going on at the bottom sediments - you can maintain the pond more or less where you want it by careful mgmt. and it will change little over a few decades
also, chemicals and fertilizer can travel 100 yards easily
if you get really, really into this you could find a textbook on limnology and read it, then dial in for your area and soil type
Old 05-02-2013, 10:51 AM
Thanks Randy! Sorry about hijacking this thread
Old 05-02-2013, 11:58 AM
