126coupe's Avatar
Nascar Race Engine
Finally got everything back from the machine shop, assembly begins
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 05-23-2013, 08:33 AM
Unregistered
sammyg2's Avatar
Dammm, how big are those intake valves?
I'm surprised they run H-beam rods 'cause of the windage, unless maybe it's a dry sump .......
Old 05-23-2013, 08:51 AM
MAGA
Tim Hancock's Avatar
I would have thought that engine would have domed rather than dished pistons for higher compression ratio. What kind of rpm will it be spinning and what kind of horsepower is this engine going to produce?
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 05-23-2013, 09:54 AM
Just thinking out loud
mattdavis11's Avatar
I imagine that the lift and duration of the cam necessitates a set of pistons that are dished to the exact shape of the heads. Otherwise, it would be an interference engine.
91 FJ80
84 Ram Charger (now gone)
Old 05-23-2013, 10:15 AM
126coupe's Avatar
Intakes are 2.13 inches, dry sump, period correct from 1993, small block ford, 11:1 CR
Should make just over 700HP, will post dyne results. The rev limiter will be set at 8200
28' Pace Trailer
Old 05-23-2013, 10:17 AM
check the combustion chamber sizes, basically just valve pockets. Domed pistons disrupts airflow and the burn. The piston reliefs are not just for valve clearance, it is effectively the combustion chamber.
Old 05-23-2013, 10:26 AM
126coupe's Avatar
Now I know why I get 2-2.5 MPG
28' Pace Trailer
Old 05-23-2013, 10:34 AM
Driver
Noah930's Avatar
Just remember, assembly is the reverse of disassembly.
Well, unless you blew up the motor on the track. Then I hope you have some sort of shop manual.
1990 Black 964 C2 Targa
Old 05-23-2013, 10:36 AM
126coupe's Avatar
These are so simple compared to what I'm used ie Porsche Engines, my wrench is a V8 guru. This a whole new beast, Block, Crank, Pistons, Rods, Valves, Springs act
28' Pace Trailer
Old 05-23-2013, 10:46 AM
Unregistered
sammyg2's Avatar
LOL, last time I built a full race v8 I put in pistons that looked like this:
Later, I bolted on a supercharger and changed the pistons to something more like this:
Old 05-23-2013, 11:04 AM
Eva
911SauCy's Avatar
This AWESOMENESS is being dropped in what...
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 05-23-2013, 12:02 PM
Zeke's Avatar
Well sammy, not all engines are hemi's.
I stopped by coupe's shop yesterday and saw what you see. In fact, I think I missed the picture session by minutes. The Ford block looks small and compact to me. I liked what I saw. They have installed roller bearings on the camshaft. It spins like a top with no lifters.
Love to be there when they fire that puppy.
Old 05-23-2013, 12:29 PM
126coupe's Avatar
28' Pace Trailer
Old 05-23-2013, 01:36 PM
Unregistered
sammyg2's Avatar
That's a good thing. No way would mine last 500 miles.
I'd love to be able to take an older stock car and strip the weight out of it, what are they stock, 3200?
Iffn you could get it down under 2500# with all that HP it'd be downright scary. Er.
Scary-er.
Prolly wouldn't be legal tho.
Old 05-23-2013, 02:40 PM
Jim Bremner's Avatar
If you need an extra hand I can be had cheap while I'm working to find work. I do know how to use a torque wrench as well as how to identify a grade 8 bolt.
Jim
Old 05-23-2013, 03:10 PM
Scary-er.
You would need a sawzall to cut out the rollcage. there's not much in dead weight on these cars.
Old 05-23-2013, 03:11 PM
Unregistered
sammyg2's Avatar
They must be pretty darn sturdy then because they are definately not light as far as race cars go.
Guess that's why they can walk away from them 200 mph crashes.
Guess that's also why those 1300# F1 cars cost $20 mil each.
Old 05-23-2013, 03:54 PM
126coupe's Avatar
28' Pace Trailer
Old 05-23-2013, 03:56 PM
Actually have to add wieght to stock cars to make weight, you could easily get these car to 2500Lbs. That why driver size doesn't matter in NASCAR.
Old 05-24-2013, 12:47 PM
Zeke's Avatar
I don't know where people find their facts. Drivers under 180 lbs. have to add weight.
And if you could provide at least a partial list of items that could be safely removed to achieve an 800# redcution, I'd like to look. But if you are telling us that aluminum can be substituted for steel, well that's not news.
Old 05-24-2013, 02:19 PM
