Pavement epoxy?
I need to fill in some troughs in my pavement, maybe a quarter inch thick in places.
Is there a thick version of garage floor epoxy that I can trowel in place? or something else? has to be hard enough to withstand a jack+car.
Tru6 Restoration & Design |
The Unsettler
Hydraulic cement? Sets up real fast. Don't know about compressive properties.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
That might work, I'll do some research, thanks Scott. I need it to level out the floor in my shelter and build a little berm to divert water in front of it as the pavement slants down in 2 dimensions. I'm now finishing up building a new one after my original got crushed under 2 feet of snow in January, this one will be much better and weather proof, just need to keep rain water from running in via two troughs in the pavement.
The frame I made from electrical conduit, half done here. ![]() Reusing the old shelter cover temporarily, new one that will wrap under and up arriving this week ![]() Started making doors with the silk screen frames ![]() Doors finished. Found that the old screen adhesive is INCREDIBLY toxic. I'm surprised I still have lungs. Got my respirator out immediately after breathing in some dust while grinding. ![]() Progress and mock-up. Had to make a spreader, nothing is square of course, neither the frame nor the ground. Backbreaking hard work. ![]() Incremental spreader. ![]() Finally just made a buttress to keep it square while welding in the sides. That worked well. ![]() Frame is nice and square. ![]() I got the doors hung end of day yesterday and I'm fairly happy with it. New cover is on the way, next I have to panel the front and the doors.
Use epoxy and mix in some sand. I did that to fill in the saw cuts in my garage floor before i did the normal epoxy coating.
Mat P 1988 911 Carrera |
Go-Kart Mozart
Check your local hardware store or HomeDespot if you want to look online. There are products for both concrete and asphalt. Some can be troweled in and others come in rope form and you melt them in. I have no idea how much weight can be supported. I just started looking into this myself. The bulk of my drive is asphalt and I have some chunking where the asphalt transitions to concrete. -J
86 Carrera Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken |
MAGA
I don't have a good answer for you, but structural epoxy would cost a fortune if you are talking about using a bunch of gallons of it.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Kantry Member
Shaun,
Neat project. If you get two feet of snow again, I suspect the snow trapped between the adjacent building and your new structure is going to jack your shelter away from the building. Best Les
Best Les My train of thought has been replaced by a bumper car. |
Electrical conduit for the frame...pretty nifty!
The box stores should have what you need to address those driveway issues.
Old dog....new tricks..... |
Mostly the snow just sits on top. But I am going to work on something so it either gets caught above the gap or all slides to the yard next to me.
Using conduit and a hay tarp, I'm into it for about 35% the cost of buying a manufactured shelter, but better, my peak is 6 feet higher.
. Good luck.
Don . "Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence." - - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View |
Quickrete self leveling floor resurfacer.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Good luck with the completion of yours. I may post a pic of mine if it turns out publish-worthy!
Navin Johnson
We have re-decked some of the big bridges that link Manhattan and Long Island to the rest of the world....
Basically removed the old composite road surface, and tried to replace it with a lighter orthotropic floor system.. In some case its worked beyond expectations, in others not so much.. Having said that we have specified thin wearing surfaces i.e. 3/8 max thickness epoxy overlays.. These have fillers of fine Basalt... (as manufactured to spec by Tamms, Transpo,Euclid, etc.) As with any overlay or surface treatment.... the most important thing for success is surface prep... No matter what product you chose... proper surface prep will be the key to success... Sorry for sounding like an infomercial.... This is some something I know a little about
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
I have had good result with Ardex. My architect even spec it out as finish flooring on one job. check out their utube stuff. Impressive product.
A lot to think about and research more, thanks everyone for the info, really opened up the field.
