-   -   Best way to fix a dent... (http://forums.pelicanparts.com/off-topic-discussions/757404-best-way-fix-dent.html)
A930Rocket 06-22-2013 02:02 PM
What's the PPOT brain trust say about fixing this dent? Use weld on studs with a puller and heat or what? It's got a couple of good creases in it.
http://forums.pelicanparts.com/uploa...1371934806.jpg
http://forums.pelicanparts.com/uploa...1371934864.jpg
http://forums.pelicanparts.com/uploa...1371934900.jpg
onlycafe 06-22-2013 02:34 PM
lots and lots of bondo?
fastfredracing 06-22-2013 02:46 PM
Is that a BMW? The metal is pretty stout in that area.
Zeke 06-22-2013 02:55 PM
I would use the studs but I might cut it open too since I can weld in a patch pretty easily. Really, a lot of ways to skin that cat.
bell 06-22-2013 03:39 PM
Just dent the other side so it matches.......you said easy lol
A930Rocket 06-22-2013 08:25 PM
Fred, yes, it's a BMW and it "took a little bump". :)
I'd have to buy a stud gun and torches to fix it, so I may look at opening it and patching it, as Zeke mentions, since I do have a mig welder.
john70t 06-22-2013 09:57 PM
Just an idea:
Cut out the corner,
Hammer metal into shape with heat,
Weld reinforcements onto backside of corner piece and add overlap at weld joints,
Fix/seal all rust while in there (except weld area),
Weld fixed back into place,
Drill hole for a standard body drain plug, and spray interior of frame area with rust preventative (liquid/paint/waxoyl/other).
Brando 06-22-2013 10:00 PM
Cut it out, straighten any surrounding bent areas and weld in a replacement piece. I don't think there is an easy way to fix that good.
slow&rusty 06-23-2013 03:39 AM
Agreed
A930Rocket 06-23-2013 03:55 PM
Half of it is covered by the front fender, so I might cut it out, beat it back in shape, weld it back on (and patch as needed) and fill the rest of it. I have some Wurth undercoating I can use to touch it up and then paint.
Thanks guys!
Zeke 06-23-2013 04:45 PM
Originally Posted by john70t (Post 7511984)
Just an idea:
Cut out the corner,
I use weld through primer on the back side. It gets burned and rusts anyway so you do need to do this ^^^^^.
Nothing rusts faster on a car than a welded repair unless you take great steps to protect and prevent rust on the welds and the weld heat zone. Actually, the heat zone is worse than the weld bead. But not by much.
Spot welding is really a terrific way to build/repair a car outside of a cold bond.
