Best way to fix a dent...
What's the PPOT brain trust say about fixing this dent? Use weld on studs with a puller and heat or what? It's got a couple of good creases in it.
i'm just a cook
lots and lots of bondo?
Is that a BMW? The metal is pretty stout in that area.
No left turn un stoned |
I would use the studs but I might cut it open too since I can weld in a patch pretty easily. Really, a lot of ways to skin that cat.
one of gods prototypes
Just dent the other side so it matches.......you said easy lol
Brought to you by Carl's Jr. |
Fred, yes, it's a BMW and it "took a little bump".
![]() I'd have to buy a stud gun and torches to fix it, so I may look at opening it and patching it, as Zeke mentions, since I do have a mig welder. |
You do not have permissi
Just an idea:
Cut out the corner, Hammer metal into shape with heat, Weld reinforcements onto backside of corner piece and add overlap at weld joints, Fix/seal all rust while in there (except weld area), Weld fixed back into place, Drill hole for a standard body drain plug, and spray interior of frame area with rust preventative (liquid/paint/waxoyl/other). Last edited by john70t; 06-22-2013 at 09:59 PM.. |
Burn the fire.
Cut it out, straighten any surrounding bent areas and weld in a replacement piece. I don't think there is an easy way to fix that good.
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
Agreed
Ole Skool - wouldn't have it any other way |
Half of it is covered by the front fender, so I might cut it out, beat it back in shape, weld it back on (and patch as needed) and fill the rest of it. I have some Wurth undercoating I can use to touch it up and then paint.
Thanks guys! |
Nothing rusts faster on a car than a welded repair unless you take great steps to protect and prevent rust on the welds and the weld heat zone. Actually, the heat zone is worse than the weld bead. But not by much. Spot welding is really a terrific way to build/repair a car outside of a cold bond. |
