Did you get the memo?
Plastic/Rubber Garage Floor Tiles
Anyone using some variety of these? I've delayed applying an epoxy floor because I'm not very confident in durability, especially using one of the DIY kits. The 12x12 or 18x18 garage floor tiles are tempting because they look good and are easy to DIY. The only potential issue that I see is impact resistance, but I suppose you just replace one if it breaks. They are also on the pricey side.
Anyone using some variety of this flooring? If so, what kind is it and how do you like it?
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
Matt - go over to GargageJournal forum - they have a segment devoted to flooring. Several floor finish company representatives are members - as well as Race Deck. Most even offer discounts to forum members - and/or free shipping.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Subscribed...
Model Citizen
I've got these:
Garage floor tiles, Garage flooring, Garage floor covering One problem i see, I don't find the exact ones offered anymore, so once my stash of extras is gone that will probably be the end - I have the hard plastic but in a "coin" pattern, not diamond plate. Cuppla things to consider- •They'll take a floor jack, but sometimes you'll notice as you're lifting that one of the wheel edges is on a soft spot. Move it slightly, so it's on a rib and you'll be happy. (Hard to describe, but obvious in practice) •You really need to put down an underlay. I used some stuff I got free at work that is very similar to the underlay for floating wood floors. Without an underlay, these have an annoying click-clop while you walk across them. Underlay makes a world of difference. •You can see that I am protecting the floor from jackstand legs by bolting some stuff to the bottom. I've had good luck with the wearability; only had to replace a few, but I don't work on my car eight hours a day. For occasional use, they're great, they clean up easy and they look good.
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
i have motofloor in my garage. like it a lot. cleaner, reflects more light and easier to work on that concrete. the white tiles are hard to keep clean. they might scratch, but don't break.
I noticed that my Costco store has rolls of Versa Roll floor covering for $150 per.
I'm tempted. . Here's a link showing $180 but in-store was less...as I recall...also, a couple of videos. . Gray 7.5'x20' VersaRoll PVC Flooring . A link with customer comments: . Costco - VersaRoll PVC 7.5' x 20' Easy to Install Garage Flooring customer reviews - product reviews - read top consumer ratings Dimensions per roll: 7.5 ft. x 20 ft. Thickness: 80 mil (2.5mm) Material: Non-Porous PVC Weight per roll: 105 lbs. Warranty: 1 Year Limited
Don . "Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence." - - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View |
The roll stuff is interesting, and way cheaper than the tiles. I wonder how that would do with jacks and jack stands?
I would place a cleat under anything like a jack/jack stand.
Like plywood or sheet steel, for example.
'99 R11S, '76 914 2.0 |
MAGA
Several years ago I powerwashed and acid etched my old 2 car garage floor then applied an epoxy floor kit from a home improvement store. We avoided parking on it for two weeks but when we did, my daughters VW beetle started taking spots of the paint of with hot tires. I ended up just buying the PVC ribbed mats from Menards to park the cars on. They have held up well and the ribs keep slush/water of the floor. My 924S leaks oil and the mat seems to no be affected. They are easy to scrub clean with soapy water and a push broom I do no work in this attached garage so I have no clue how they would fair. The epoxy areas of the floor that are not covered still look great but they only ee foot traffic.
I would love to epoxy my hangar/workshop floor, but I would only have it professionally done after seeing how poorly the garage epoxy held up to hot tires. It would cost a fortune to do an area the size of my shop and I am a cheap SOB so I doubt it will ever happen. For an average sized garage that I intended to work in, I would likely consider buying a boatload of large ceramic tile on sale somewhere similar to what Jack did.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
If its going to be a real working garage, why not just clean it and seal it? Easier to sweep and wipe up. Spend the extra money on go fast goodies.
be here now
Just sold our house and downsizing to a much smaller house and unfortunately....smaller garage. It will not be a real "working garage" since my engine rebuilding-restoring-fixing everything days are over.
Seriously thinking laying these down..... Welcome to TechFloor; A MacNeil Automotive Product | TechFloor
Rob.... '66 911, '74 911, '85.5 944, '69 914-6, '65 356C, '01 986, '04 955S, '97 993 C2S, '55 356 OUTLAW, '98 993 Cab, '55 356 Speedster, '06 955S, '58 356A, '96 993 C4S, '87 BD 911, '95 993, '06 997S, '11 997.2S, '74 914 2.7, '15 981S |
I've done a transmission pull on an S10 pickup on my back on a rubber floor, it was a very, very, nice. Almost wanted to take a nap at one point, and it was also nice and warm.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
beancounter
I've got racedeck in my workshop. Looks good, easy to install and so far holding up well.
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
I have a roll of the ribbed stuff. I use it inside my travel trailer you hauler so oil etc doesn't stain the floor. It's pretty easy to clean, but can be painful to walk on barefoot.
Bill |
I have Race Deck in a black/white checkerboard pattern; it was pretty expensive, but did it when I built the garage, so added it to the home equity loan, otherwise I think I would have a hard time spending that much again. It was amazing how nice the garage started looking while I was installing it, made a huge difference in how the garage looked; I had a new garage with clean concrete and everything drywalled and painted white, but the floor made the place beautiful. I used a table saw and jig saw to get the edges to fit perfect.
Couple things, first it does scratch pretty easy, but doesn't change the look much; it cleans up easy enough; the heat from the 911 causes the floor to buckle when I first pull in, but it goes back flat when cool; it also shifts a little when driving on it(1/2" or so, goes back when driving out.) I always put boards under jack stands, so don't know if they would crack otherwise. Best, Rutager
Rutager West 1977 911S Targa Chocolate Brown |
I think I need to fix my concrete floor first of it's cracks and uneven spots before I try anything like these tiles. I have looked into a checkerboard style floor and didn't really want to spend $500 plus underlayment, and concrete fix cost.
JORGEN 20 C4S - Chalk 22 GT3 Touring - Auratium Green 96' 993 Turbo - White with Flamenco Red Interior 73' RS hotrod 3.6L - |
anyone have experience with Swisstrax?.... Jay Leno's Garage - Garage Floor - Rubber Floor Tiles - Shop Flooring - Modular Trade Show Flooring
76' 911s Signature Edition |
be here now
I went with TechFloor tiles.....
