Printing JPGs: how can this happen?
I gave our screen printer JPGs of our Fall t-shirt designs to print film and get the shirts done.
This particular JPG is 1200 dpi (other shaded layers go through a linescreen filter so easier for the whole PS file, then JPG layers to be high res). Here's my printout, both on a laser printer and then inkjet on film. Each letter has perfect, crisp edges. http://forums.pelicanparts.com/uploa...1374012295.jpg And here's what they are printing. Edges are entirely pixelated. How does that happen? I could understand if a PS file and they didn't have the font, but this is a JPG. Any ideas? http://forums.pelicanparts.com/uploa...1374012486.jpg |
It is likely their RIP software. It is down sampling the file or their printer is not set up right.
Edit: nevermind, misunderstood question..
The RIP is screwing it up. I've had this problem in the past, but not since I started sending everything to my printers as PDFs. Apparently the JPG standard has been around long enough to have developed a few mutations that RIPS don't like.
IT'S HAUNTED!
run away, run away ;) |
Thank you Glen and Patrick, I'll send some PDFs and see what happens, also ask them to disable their RIP software.
?? If they are going to turn it into a screen they have to rasterize it.
We just print on film, like you would print on paper, tape the positive to a screen, burn it, wash it out (where there is printing, the screen washes out), done.
General rule of thumb, don't send service bureaus files in a compressible format.
If you are designing the text in Illustrator (you should be) send an outlined version. Never have to worry about missing fonts or quality. Select all then Command+Shift+O |
Scott, I do (Illustrator text, outlined, then pasted in PS).
They wanted the JPGs. I had originally given them PS files. |
| All times are GMT -8. The time now is 01:19 PM. |
