Shaun @ Tru6's Avatar
Printing JPGs: how can this happen?
I gave our screen printer JPGs of our Fall t-shirt designs to print film and get the shirts done.
This particular JPG is 1200 dpi (other shaded layers go through a linescreen filter so easier for the whole PS file, then JPG layers to be high res).
Here's my printout, both on a laser printer and then inkjet on film. Each letter has perfect, crisp edges.
And here's what they are printing. Edges are entirely pixelated. How does that happen? I could understand if a PS file and they didn't have the font, but this is a JPG. Any ideas?
Tru6 Restoration & Design
Old 07-16-2013, 03:09 PM
It is likely their RIP software. It is down sampling the file or their printer is not set up right.
Old 07-16-2013, 03:33 PM
I have sinned!
gorthar's Avatar
Edit: nevermind, misunderstood question..
Old 07-16-2013, 03:37 PM
wdfifteen's Avatar
The RIP is screwing it up. I've had this problem in the past, but not since I started sending everything to my printers as PDFs. Apparently the JPG standard has been around long enough to have developed a few mutations that RIPS don't like.
Old 07-16-2013, 05:01 PM
Unregistered
sammyg2's Avatar
IT'S HAUNTED!
run away, run away
Old 07-16-2013, 05:04 PM
Thank you Glen and Patrick, I'll send some PDFs and see what happens, also ask them to disable their RIP software.
Old 07-16-2013, 05:27 PM
wdfifteen's Avatar
?? If they are going to turn it into a screen they have to rasterize it.
Old 07-16-2013, 05:39 PM
We just print on film, like you would print on paper, tape the positive to a screen, burn it, wash it out (where there is printing, the screen washes out), done.
Old 07-16-2013, 05:46 PM
The Unsettler
stomachmonkey's Avatar
General rule of thumb, don't send service bureaus files in a compressible format.
If you are designing the text in Illustrator (you should be) send an outlined version. Never have to worry about missing fonts or quality.
Select all then Command+Shift+O
"I want my two dollars"
"Brandon Won"
Old 07-16-2013, 06:25 PM
Scott, I do (Illustrator text, outlined, then pasted in PS).
They wanted the JPGs. I had originally given them PS files.
Old 07-16-2013, 06:28 PM
