Registered ConfUser
Jeep Oil Pressure - Too high?
Drove my son's Jeep Cherokee (99 2WD 4.0L straight six) yesterday for the first time in a while. I noticed the oil pressure guage showed almost max pressure (80psi, and only drops slightly at idle). We changed the oil/filter and no difference. It is not over filled. Perhaps it's always read high and I just didn't notice, or maybe a guage out of calibration.
It runs great in every regard even with 166k on the clock. He'll be taking it to college in a few weeks (5 hours away). Any reason for concern? Anything I should check?
Mike
Old 07-27-2013, 11:27 AM
Zeke's Avatar
See if you can find the values for the sending unit and put a meter on it. If it's not too much, swap it out. That will be the cheapest fix if it's is the fix.
Old 07-27-2013, 11:30 AM
time wasting tosser
Highlander179's Avatar
Replace the sending unit, aka oil pressure switch. They are known to go bad. Should be like 30bux.
The beauty of the jeep is that it will run with zero pressure or almost no oil at all. Not a big worry, but the sending unit is the problem. Check out jeep forums.
https://www.google.com/#sclient=psy-ab&q=2001%20jeep%20cherokee%20high%20oil%20pressure&oq=&gs_l=&pbx=1&bav=on.2,or.r_cp.r_qf.&bvm=bv.49784469,d.dmg&fp=f91cd8e5275c41e&biw=1249&bih=558&pf=p&pdl=300
Old 07-27-2013, 12:44 PM
You do not have permissi
john70t's Avatar
This is the opposite of any early pcar owner: Where the dash guage drops to zero at idle.
Old 07-27-2013, 01:45 PM
1966 - 912 - SOLD
lane912's Avatar
my ford ranger has a bad sender, makes the needle jump randomly-
i was too tired to be pretty last night!
Old 07-27-2013, 02:16 PM
Registered ConfUser
Yep, that makes sense. Turned the ignition on without starting the engine and it shows 20psi. Will replace sender. Thanks.
Old 07-28-2013, 04:19 AM
