I see you
flatbutt's Avatar
"Frozen" calipers
'06 Taco, 95k miles and I'm on my third set of brake calipers. WTF? I don't do off road. It only sees about 200 miles/week during the summer but even so I don't see lack of use as a problem do you? Ideas?
Old 08-15-2013, 08:00 PM
Parrothead member
VINMAN's Avatar
Whats locking up the piston or the caliper slides?
Vinny
Old 08-15-2013, 08:02 PM
You do not have permissi
john70t's Avatar
The piston either works or it doesn't.
If one pad is wearing faster, it's probably the slide (cause=cheap grease).
Same thing happened with my new 'foreign made' set from napa. The piston rusted and froze in a year or two w/new dot2 and flush.
Old 08-15-2013, 08:31 PM
canna change law physics
red-beard's Avatar
Are you sure it isn't the brake line? Old front flexible brake lines eventually swell up inside and become one way check valves.
James
Red-beard for President, 2020
Old 08-15-2013, 08:33 PM
I see you
flatbutt's Avatar
piston
Old 08-15-2013, 08:52 PM
I see you
flatbutt's Avatar
i.ll keep an eye on the lines but should I jizz the pistons now and then?
Old 08-15-2013, 08:55 PM
Scott R's Avatar
The rears?
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 08-15-2013, 09:06 PM
AutoBahned
RWebb's Avatar
if the hoses are > 7 years old or age is unknown then replace them with new factory rubber hoses
- that is a must do on any used car I buy
you can check the piston operation manually when you have the hose off
do all 4
but NO, do not get any jizz on the pistons - surely you can afford brake paste...
Old 08-15-2013, 09:19 PM
vash's Avatar
i have a 2006.
do they freeze up after a car wash?
poof! gone
Old 08-15-2013, 10:03 PM
Captain Annoying
SteamWolf's Avatar
+1 for failed brake hoses. Calipers are generally ultra reliable. Repeat failures are so unusual as to be a good indication that the problem is elsewhere.
What's the actual symptom?? Brakes dragging? Do they free up if you crack the bleeder? If so, something in the system is holding residual pressure. Either brake hoses, or a poorly fitted master/booster or a faulty ABS system.
this time for sure...
Old 08-15-2013, 10:19 PM
vash's Avatar
do all 4
we have drums in back. they barely work. just kidding they work fine.
poof! gone
Old 08-15-2013, 10:26 PM
I see you
flatbutt's Avatar
Manifests as a very low brake pedal, minimal braking power.
Old 08-16-2013, 05:24 AM
I see you
flatbutt's Avatar
do all 4
ha! OK but brake paste? Is there a lube for the pistons? I replaced the hoses this time around.
Old 08-16-2013, 05:26 AM
pete3799's Avatar
I'm in the process of patching my frame back together again on mine (03).
Never had any brake problems.
Still got the original calipers on it with 160K miles on them.
Pete
79 911SC RoW
Old 08-16-2013, 06:04 AM
White and Nerdy
Tervuren's Avatar
+1, I tore apart the calipers on both my 944's, 7 out of 8 were in great shape, the one that had minor surface rust on the piston, had a pinched off brake line going to it.
Have you actually checked that the calipers you are taking off are bad? What does bleeding do? Are you losing brake fluid?
Shadilay.
Old 08-16-2013, 06:37 AM
I see you
flatbutt's Avatar
pistons are frozen, I couldn't make them move, Bleeding as a first action did nothing. No fluid loss.
Old 08-16-2013, 06:54 AM
White and Nerdy
Tervuren's Avatar
Have you taken apart any of the pistons you replaced to see what they are like inside?
Shadilay.
Old 08-16-2013, 07:00 AM
Functionista
manbridge 74's Avatar
Has the m/c or booster been replaced?
Could someone have spaced checking the clearance of the rod going from booster to m/c causing brakes to drag?
What kind of caliper is going back on, OE or aftermarket?
Do calipers show(as best you can tell) water/salt getting by dust seals?
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 08-16-2013, 07:44 AM
AutoBahned
RWebb's Avatar
Unisilikon TK 44 N brake paste - Porsche part # 000.043.117.00 for a 50 g tube
if your wife finds out about the cost, tell her it is like face cream
do NOT do all the calipers at once - do 1 only then drive 100 miles or so; do the another, etc. - I assume car is driveable...
Old 08-16-2013, 01:14 PM
Functionista
I remember Toyota brake pistons being anodized in the 90s. Perhaps they discontinued this causing corrosion to occur sooner?
Jeff
74 911, #3
Old 08-16-2013, 02:12 PM
