-   -   what glue to use for bricks? (http://forums.pelicanparts.com/off-topic-discussions/766743-what-glue-use-bricks.html)
rnln 08-19-2013 02:40 AM
I have been doing my flower bed using retainer bricks. I tick them together by Loctite 375. Once, I needed to take couple bricks off after 2 days, I couldn't. So, I thought that this loctite 375 is great. But when it's wet, it is a different story.
Now, I have a small portion left, and want to use better glue. Does anyone know what kind of glue is better, can stand diff weather wet and dry, more permanent?
BTW, the white stuff is after the bricks are wet, after the rain.
http://forums.pelicanparts.com/uploa...1376905157.jpg
A930Rocket 08-19-2013 04:46 AM
All I know is silicone doesn't work.
M.D. Holloway 08-19-2013 04:55 AM
I don't want to sound trite but what's wrong with mortar ?
VINMAN 08-19-2013 05:01 AM
PL masonry adhesive. Best stuff out there
URY914 08-19-2013 05:11 AM
Mix up a batch of JB Weld in a 5 gallon bucket.
There are masonry adhesives that come in tubes like caulk. Any big box home improvement center should have them.
HardDrive 08-19-2013 05:18 AM
Very confused. Why are you glueing a retaining wall together?
Don Ro 08-19-2013 07:22 AM
Yes, I've used this product w/great results!
john70t 08-19-2013 07:32 AM
Guessing it doesn't provide the lateral sheer strength.
There's not too much uphill of that wall.
Probably doesn't need much glue except for the cap.
The interlocking joints do most of it.
1990C4S 08-19-2013 09:24 AM
Normally the cap is glued on. Use PL adhesive, or there is a strip of adhesive they sell with the brick.
wdfifteen 08-19-2013 10:06 AM
Nice wall. I like the way it curves.
Scott Douglas 08-19-2013 04:04 PM
I think my son used Liquid Nails glue when he built his wall.
http://forums.pelicanparts.com/uploa...1376953445.jpg
juanbenae 08-19-2013 04:17 PM
you can get the equivalent of liquid nails in a bigger tube under the name subfloor glue. you will need a bigger type caulking gun, but the bigger tubes cost savings might offset the cost of the gun. ive used it to glue down pavers to a concrete patio, in addition to 1000's of SF of t&g plywood subfloor and it worked well...
rnln 08-20-2013 01:30 AM
This is what I used: http://www.homedepot.com/p/Loctite-PL375-28-fl-oz-Heavy-Duty-VOC-Construction-Adhesive-1390599/202020479#.UhMpPD9f1aQ
M.D. Holloway, If you want motar, you have to have at least 1/4" or 1/2" between the bricks. I want no gap, as you can see in the pic. Also, the surface where they meet is flat. I don't think motar will make it very strong.
VINMAN, I searched on "PL masonry adhesive" and found "Loctite PL Premium 28 fl. oz. Polyurethane Construction Adhesive". Similar to what I used, except it is premium instead of 375. Is that it?
john70t, I broke the join so the surface can be even, no gap.
wdfifteen, thanks.
Scott, nice bed scott. For me, it took a long time. I also built couple columns with the same type of brick. The one against the wall, I want to fill it with concrete and bars inside in case any drunk driver wants to test his car.
To those who recommended PL masonry adhesive, is this what you are talking about? Loctite PL Premium 28 fl. oz. Polyurethane Construction Adhesive-1390594 at The Home Depot
Thanks all.
onewhippedpuppy 08-20-2013 04:24 AM
We used some variety of masonry adhesive and I wasn't impressed, we've had a few issues with blocks coming apart at exposed areas like the end of a wall. Sadly I don't think there are any better options.
A930Rocket 08-20-2013 06:54 AM
That "white stuff" looks like efferesence (sp?) where minerals are leached out by water. Putting a vapor barrier behind the wall will help. You can clean it with a mild solution of water and acid.
gr8fl4porsche 08-20-2013 07:05 AM
I thought the same thing especially since you can see it on the blocks sitting next to the wall.
Are you sure that's glue you're seeing?
If it is efflorescence, clean it off quick with a mild muriatic acid solution and a powerwasher. Once it accumulates for a while it becomes harder than the block. There are other chemicals available for removal of efflorescence that may work as well.
The downside is that unless conditions change, the efflorescence will keep coming back. You need block or mortar containing lots of salts and moisture problems to produce efflorescence.
ossiblue 08-20-2013 07:17 AM
Looking back, I tend to agree that what you show is efflorescence. Notice the blocks stacked to the side that haven't been glued--they have the same white marks. If that's the case, then do as suggested and clean off the residue and, if possible, put a moisture barrier between the blocks and the dirt behind.
1979 930 08-20-2013 05:54 PM
Best stuff in the world is 3m 5200 its a marine adhesive !!! You will never put them apart!!!!
rnln 08-20-2013 11:29 PM
A930Rocket,
the white stuff... I do have a layer of thick rubber like behind the wall, but it's still there after the wall is wet. I tried to spray wd40 and brake cleaner on some of the blocks just to see if they work. Yes, they work for a while but eventually it came back after a rain. In summer, it's automatically gone.
No, it's not the glue.
Alright, will search for the 3m marine stuff.
Thanks.
