Takin' hard left turns
Amail's Avatar
Inline garden hose regulators - Question for PPBT
Our irrigation system is a wreck and we've been using sprinklers and a hose for quite a while. We have trouble maintaining water flow when we need to water at low volume.
I can't find a good inline water flow regulator. My ideal would be a small device to go on the end of the hose onto which I could attach a 15' length of hose. We could just leave it full blast at the hose bib, but fine tune the flow at the attachment near the sprinkler. And, it really really needs to maintain the flow unless the main pressure drops below our desired pressure.
I'm no plumber or irrigation expert, but I figure this place must have someone that is. Does anyone know of such a device?
Old 08-30-2013, 05:04 PM
Zeke's Avatar
When did watering become so precise? Do you have that much variance in pressure during a watering cycle? Anyway (I didn't look) you might try the Rainbird site or there is an irrigation supply in Signal Hill near me that might know about such a thing. They won't be open until Tuesday. It's called Ewing.
Old 08-30-2013, 05:21 PM
Try a place called Carson Irrigation supply in Cypress. They are on Lincoln Blvd
Old 08-30-2013, 06:52 PM
DIG Corp 25 psi Hose Thread Pressure Regulator
DIG's preset pressure regulators keep your drip system at the right pressure. This female hose thread inlet - male hose thread outlet regulator provides a steady, low flow of water crucial to drip irrigation systems. Offers protection for emitters that could be damaged due to excessive pressures.
3/4 in. FHT x 3/4 in. MHT
Installs easily after the valve on a drip system
No special tools or glues necessary
Ensures excessive water pressure does not damage drip systems
Made from durable, UV resistant materials for long life in the landscape
MFG Model # : D46
MFG Part # : D46
Available at HD or online.....
DIG Corp 25 psi Hose Thread Pressure Regulator-D46 at The Home Depot
Old 08-30-2013, 06:58 PM
You could also include a ball or gate valve to also help regulate but maybe this thing by itself along with your hose bib would be all you need.
Old 08-30-2013, 07:00 PM
Banned
Ummmmm.....a 7 dollar valve you can buy a Home Depot?
I'm just sayin'.....
Old 08-30-2013, 08:10 PM
Amail's Avatar
Thanks for the suggestions. The biggest problem is our pressure varies over the course of 30 minutes so a good flow rate at first becomes too much or too little at the end, especially at low flows. A simple valve would do it if the pressure were steady, but it's not.
Old 09-01-2013, 09:20 AM
