Fleabit peanut monkey
Bob Kontak's Avatar
Help - old ( 77) Corvette engine in pieces
Laying in my shop taking up space Is it worth even putting on Craigslist?
I am cleaning out junk and have a 1977 corvette engine in pieces a guy was going to rebuild and his wife said get it out. I bought tools and a workbench from him cheap on the condition the engine parts go.
The block says "010" on it which I think means some extra nickle content in the block but it is not a four bolt main.
Scrap it of hassle with selling it?
I also have the auto trans. Suspect that my be worth something. It's not in pieces.
1981 911SC Targa
Old 09-05-2013, 08:09 AM
D idn't E arn I t
RANDY P's Avatar
010 virgin bore block is desirable. Sell it on CL, it'll be gone quick.
Perfect candidate for splayed main caps. If you were closer I'd get it right now.
$300 come and get it? (everything, that is)
rjp
In the movies only bad guys sleep in king size beds.
Old 09-05-2013, 08:14 AM
Bob Kontak's Avatar
So I could mic the bores and see if it's not been re-bored - is that "virgin"? EDIT: duh - I see where you said bore after virgin
$300 sounds pretty good. Does that include the trans?
1981 911SC Targa
Old 09-05-2013, 08:19 AM
D idn't E arn I t
RANDY P's Avatar
Yep.. someone will take it
Old 09-05-2013, 08:23 AM
Bob Kontak's Avatar
Sweet - worth a little hassle then. :-)
Many thanks. I will advise as to outcome.
1981 911SC Targa
Old 09-05-2013, 08:24 AM
D idn't E arn I t
RANDY P's Avatar
ONE LAST THING- the crank if it's what I think is a FORGED unit- worth more $$$
maybe $400 for everything- take a look at the parting line from the casting on the crank, if it's a thin line it's a cast crank-
If it's about 1/2" thick and looks flattened it's a forged unit. Obviously the forged is desirable
Old 09-05-2013, 08:35 AM
Laneco's Avatar
You might take a little time to advertise with the Corvette people. In 1977, the 350 engine was pretty low on power and a lot of people junked them to put in a high performance engine. But the 70's era Corvettes have been appreciating in value and to someone putting one back together, this might actually be desirable. Not big $$$ desirable, but if all the bits are there (intake, smog crap, etc) perhaps more than a couple of hundred bucks.
Either way, worth the effort.
angela
Hello
Old 09-05-2013, 09:02 AM
Bob Kontak's Avatar
Cast crank but bore is 4" so that is good.
There is a 4 bolt main 010 block but that I do not have.
1981 911SC Targa
Old 09-05-2013, 09:17 AM
Bob Kontak's Avatar
angela
Thanks. Not big money but not worthless. Ad is now posted.
1981 911SC Targa
Old 09-05-2013, 09:20 AM
Edministrator
Steve Carlton's Avatar
I'll give you $300 for everything if you include shipping.
Good post? Leave a tip!
O - $1
O - $2
O - $3
Old 09-05-2013, 09:45 AM
Edministrator
Just kidding.
O - $1
O - $2
O - $3
meister member
speedracing944's Avatar
I have a '78 where the lifter collapsed and the rear main is leaking like mad. If you were closer I would snatch up the whole deal.
I wonder if it is a L48 or a L82 motor? Do you have a picture of the valve covers?
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 09-05-2013, 06:21 PM
Bob Kontak's Avatar
Speedy
I know it has two bolt mains and a cast crank. There is a casting number on the rear top of engine that is 397XX1X - but the X's look like they could be a zeros sixes or nines - maybe eights. There is slag where these numbers are.
Also in chain housing on block there is an 010 and a G26. Cams look pretty pointy on the lobes - not a heavy breather - but I doubt many were in the late 70's.
1981 911SC Targa
Old 09-06-2013, 07:39 AM
AutoBahned
RWebb's Avatar
why not send it to motor meister?
Old 09-06-2013, 11:55 AM
