-   -   Need lightweight roofing solution (http://forums.pelicanparts.com/off-topic-discussions/769914-need-lightweight-roofing-solution.html)
widebody911 09-09-2013 10:29 AM
For superior protection, use butyl tape caulking on your side and butt laps as well.
I had considered laying a bead of some sort of roof sealant between sheets
Eric 951 09-09-2013 10:32 AM
Tape caulking is easier than tube and not as messy if for some reason you need to relocate the sheet. You can use a 2-corrugation side lap as well instead of 1.
emcon5 09-10-2013 11:30 AM
Originally Posted by Zeke (Post 7643900)
Thom, with your skills you can make the molding or strips. You don't need a continuous one either. Cut some rounds with a hole saw and chop them in half.
I can't help you with lowering the whole thing. That just seems like a lot of work.
If I was a betting man, I would guess the $300 strips are their way of not having to pay warranty claims.
widebody911 10-30-2013 07:14 PM
I finally started this project; over the past couple of weeks I got all of the adjustments and welding done, and yesterday I started on the new roof. I decided to go with metal because I didn't want to do this all over again in 5 years. If rain noise becomes an issue, I'll lay down an elastomeric coating
http://forums.pelicanparts.com/uploa...1383185284.jpg
http://forums.pelicanparts.com/uploa...1383185341.jpg
http://forums.pelicanparts.com/uploa...1383185554.jpg
http://forums.pelicanparts.com/uploa...1383185587.jpg
john70t 10-31-2013 06:05 AM
-X bracing at the corners
-general LED lighting and spotlights, on separate switches
-pull down air reels and extension cords
-outdoor speakers
widebody911 10-31-2013 06:23 AM
-outdoor speakers
The structure is pretty stout, but I have considered adding extra bracing
I like the LED light idea
I have power and air running out there already, although not on a reel
This structure is primarily for storage, so I don't really need speakers.
widebody911 11-03-2013 02:17 PM
Got most of the roof done; just a couple of fiddly bits here and there and I want to put a rain gutter on the trailing edge.
http://forums.pelicanparts.com/uploa...1383516866.jpg
http://forums.pelicanparts.com/uploa...1383516874.jpg
http://forums.pelicanparts.com/uploa...1383516899.jpg
emcon5 11-03-2013 02:20 PM
Originally Posted by widebody911 (Post 7737231)
... I want to put a rain gutter on the trailing edge.
I was wondering about that, is it sloped that direction?
widebody911 11-03-2013 02:23 PM
It is sloped toward the front of the cars. When it rains, there's a nice waterfall effect.
Seahawk 11-03-2013 02:44 PM
Well done. It fits.
Beautiful cars.
