cantdrv55's Avatar
Is this Boxster a good deal?
I think it is if it checks out.
2001 Boxster S
130 k miles
New top with glass window
Condition very good int and ext
6 speed
2 owners
Private party seller both times
$8500
He was going to trade it in but dealer was only giving $6500 so he said GTH!
Old 10-01-2013, 08:49 PM
Did you get the memo?
onewhippedpuppy's Avatar
Hell yes. It's really hard to find a Boxster S for under $10k. Assuming that it's mechanically and cosmetically sound, buy it!
‘07 Mazda RX8-8
Old 10-01-2013, 09:11 PM
Hell Belcho
Nostril Cheese's Avatar
A few things to check..
CV Joint boots. The use of the six speed in the S puts the CV joints at a different angle. They wear out frequently.
Has the water pump been changed? If not, plan to change it.
Use a good diagnostic software or the PIWIS and check cam deviation. This is a sure fire way to check if the IMS is going. The IMS problem is a bit overblown by some people, but it does happen. Replacement isnt that bad for a DIYer. Change the rear main seal and chain tensioners while you're at it.
If all checks out, enjoy the car. They are fun little rockets to drive.
Old 10-01-2013, 09:17 PM
Cajundaddy's Avatar
A very sharp price on a well maintained car with receipts. PPI and buy!
2009 Cayman PDK With a few tweaks
2021 Cayman GTS 4.0L
2021 Macan (dog hauler)
Old 10-01-2013, 09:19 PM
Now in 993 land ...
aigel's Avatar
I have followed the S and the lowest I have seen is $12k for higher mileage. Definitely anything under $10k is GREAT, if it checks out. That's a TON of car for the money. I'd jump on it - but I need another car like a hole in my head.
G
81 SC (sold)
Old 10-01-2013, 09:59 PM
cantdrv55's Avatar
Same here. Don't really need another car but I just want one. Dunno, might sell the SC if the Boxster sings to me.
Old 10-01-2013, 11:26 PM
JW Apostate
trekkor's Avatar
Score!!
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 10-01-2013, 11:47 PM
I'm with Bill
Rick V's Avatar
Don't do that, keep them both.
I drive my Boxster every day and have the SC in the garage and drive it when the mood hits, they are very different cars. Once the novelty of the new wears off you will regret getting rid of the SC and keeping the Boxster. You already know the SC value is going up, I doubt Boxsters will ever really be "wanted cars".
The Boxster is one of the best cars for fun you will ever come across, I love mine and I really don't like convertibles.
Old 10-02-2013, 02:52 AM
Almost Banned Once
sc_rufctr's Avatar
Great price but at 130k miles I would be concerned. Does it have a full service history?
What about the tyres? Are they good? Do all four match? Etc etc...
Converting to Kms that's over 200,000 and personally I would consider that very high regardless of price.
My daily is close to 300,000 Kms and still going well but it's only a matter of time before I'll be looking for something newer.
If it all checks out then go for it but slow down and really be critical of the car. Buy with your head not heart.(if possible)
- Peter
Old 10-02-2013, 03:48 AM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
Sure, factor in the cost of any necessary replacement tyres when making your offer, but that is an easily quantifiable matter, so nothing to wory about compared to unkown mechanical problems.
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 10-02-2013, 04:18 AM
Almost Banned Once
sc_rufctr's Avatar
@ 130k that's my biggest concern. How good are these motors/gearboxes?
Assuming it won't have the IMS or D chunk issue.
- Peter
Old 10-02-2013, 04:41 AM
I've never read of this IMS detection method before, thank you for posting this information.
I've got 130k on my 1977 911, how different is that from 130k on a Boxster-S?
Like someone said, an under 10k "S" looks like a quick sell price.
I had to look up the D-Chunk issue, never heard of it before.
http://www.pelicanparts.com/techarticles/Boxster_Tech/13-ENGINE-Common_Engine_Failures/13-ENGINE-Common_Engine_Failures.htm
Excess vibration and twisting from the normal operation of the engine appears to be causing some cracking in these liners, resulting in a small chunk of the liner breaking off. This “D-chunk” problem seems to ironically occur mostly in gently driven cars. Boxsters that are driven hard at the track or on the street do not tend to see this type of damage. At least with respect to the track cars, one theory is that these cars tend to have their oil changed much more often. The problem affects mostly the 2.5 and Carrera 3.4 engines: the 3.2 Boxster S engine appears to be unaffected because it has thicker cylinder walls than the 3.4 engine. When this failure happens, you will see oil and coolant begin to mix together, or a slight unexplained coolant loss.
The car in question is a 2.7 L, right?
Old 10-02-2013, 06:09 AM
Boxster S is 3.2. There are lots of M96 engines over 100k, except for the occasional IMS they are very reliable.
Old 10-02-2013, 06:35 AM
Now in 993 land ...
aigel's Avatar
Update???
81 SC (sold)
Old 10-03-2013, 10:20 PM
cantdrv55's Avatar
Silence from the seller. He might have sold it to someone else while I was away on business. I told him I couldn't come by to see it until next weekend.
Old 10-03-2013, 11:42 PM
