LinkBack Thread Tools Rating: Thread Rating: 2 votes, 1.00 average.
Hell Belcho
Nostril Cheese's Avatar
Bringing this back from the dead..
So, I did some more checking and ddid thee following
Rebuilt carb to stock Edelbrock specifications.
Carb spacer added.
Carb body cleaned out
floats checked
replaced fuel pump. As hardflex suggested, the fuel pump was leaking.
Fresh oil and filter
timing set as best I could.
She starts up easily now, fast idle set, choke works.
However she still drinks gas. Took a 1/4 gallon of fuel to move it 50 feet today.
Any ideas?
Old 02-15-2014, 08:57 PM
I would confirm basic stuff like a compression check , plugs all firing ,looking at the plugs will show if it,s running filthy rich or firing correctly at the same time. Brakes dragging? If it,s been sitting a long time a fuel gauge isn,t the best way to measure actual fuel consumption in 50 ft either.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 02-16-2014, 04:13 AM
Hell Belcho
Um, this is running the truck with the fuel line in a gallon can of gas. Didnt feel like i should run it from the tank.
Old 02-16-2014, 04:15 AM
That at least helps confirm the bad mileage but also consider you might have used a quart to fill the empty carb,pump and lines.. Still I would confirm the basic health of the engine next.
1995 993 coupe
2012 Boss 302
Old 02-16-2014, 05:09 AM
Shifter's Avatar
I know you probably don't need it, but this looks to be a good price for a parts car...
1972 Jeep J4000 4x4
Old 02-17-2014, 06:24 PM
Hell Belcho
Nope. We want this truck gone. Its for sale.
Old 02-17-2014, 06:35 PM
I like the Carter 4 barrels. haven't had much exp with Edelbrocks but they cant be much different. I have two carters on my 426
Old 02-18-2014, 05:50 AM
Hell Belcho
Roughly 160psi on all cylinders. Fresh oil.
Cant figure out why this thing is drinking some much fuel..
Old 02-18-2014, 09:09 AM
Is the vacuum and mechanical advance working correctly ?
An old vac advance unit will often have a leaking diaphragm .
1995 993 coupe
2012 Boss 302
Old 02-18-2014, 09:27 AM
Josh D's Avatar
Just to offer some moral support! This is my '71. I've had it for 12 yrs. When built right, the AMC V8's make great power and are very reliable. Mine is a 360 I built with both power and reliability mods. It's a strong motor.
I run a 600 cfm Holley with offroad needle and seats and a crossover bowl vent. It works decent offroad, but sure isn't fuel injection!
'80 RoW 911 SC non-sunroof coupe in Guards Red
It's not a Carrera.... It's a Super Carrera!
Old 02-18-2014, 09:33 AM
Hell Belcho
It's a Mallory HEI with less than 10 miles on it.
Old 02-18-2014, 10:10 AM
Team California
speeder's Avatar
I wouldn,t expect miracles with fuel mileage with any changes though.
Hahaha...wise words. I love the looks of those trucks as well but it's almost like they intentionally designed them to be inefficient is those days.
Old 02-18-2014, 01:43 PM
Hell Belcho
Jeep Other Gladiator | eBay
Now on Ebay..
Old 03-09-2014, 09:31 PM
