Question for the PC tech guys
Hi guys.
I bought a new cable a month ago that goes from my PC to my monitor ( TV). The is the large 15 pin cable with male pins on both ends. Today I unplugged one end at the TV when moving TV. After plugging it back in I lost the blue gamma on my display . The TV colour and picture is perfect but in PC mode the colour is off and adjusting the blue gamma has no effect.the other gamma colours adjust fine.drivers are updated. I did an ohm test on the cable and found one pin on the top row and one pin on the middle row with no continuity from one end to the other. My question is . Does anyone know if there should be continuity between every pin. Could that be the cause of my problem? Are these cables that fragile. thanks in advance Bruce |
Hi Bruce. I'm a bit out of date with VGA if this is what it is. I'm suspecting the TV doesn't know about the low resolution output from the computer which is probably about 640 lines. Can you change your TVs resolution. Just an idea, I hope it helps.
It is a VGA cable Bill
The res is 1360/768 It's been fine untill today when I undid the cable to move TV. I plugged it back in and turned PC back on and right away I noticed the lettering was yellow and the blue XP screen is green not blue. After trying a bunch of adjustments I found that the blue gamma was not working . The cable is the only thing I touched so checked it and found the no continuity issue between two pins. |
Wiggle the connector at each end.. They can go bad. Watch the TV while wiggling and pushing..
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
slodave thanks. I wiggled ,removed switched around the ends today but when you said wiggle I tried again. wiggling the plug does nothing but bend the cable a little where it goes into the plug and bingo back to normal.
You know when I bought the cable the guy said there is a one year replacement warrenty on the cable and i thought what can go wrong with a cable .I touched it once and a problem happens.obviously a break or something where it goes into the plug so back it goes. Thanks again guys for chiming in so quik.It was p...ing me off and now i can go to bed knowing prob is fixed. thanks again Bruce.. |
You're welcome.
A little side story... I used to think that power cables for PC's never went bad. Plug them in, tuck the pc away and the cable never moves, should not have issues. Took me probably two occasions that were far apart to realize that the power cable can fail too. Some of the older cables are a bit heavier duty than the newer cables - thought the old ones would be the best. Wrong!
I now change out the cables with what comes in the box with a new PC/power supply, regardless of the age/how it looks.
Still Doin Time
My experience: where was the last place you had your hands? Then check for the obvious human fault factor, then replace the cable.
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
The Unsettler
How old is this monitor / TV?
Does the VGA cable plug in and stick of the back horizontal or does it hang vertical? Horizontal ones can put strain on the connector and if a solder point cracks you'll get that. Back in the day we had a bunch of Radius 21 in monitors, real expensive mothers. They all started failing around the same time. VP of IT was going to dump them. Told him I thought they could be fixed, he didn't care, told me to take them if I wanted them. 5 minutes with a soldering iron and they were good to go. Sold them for $250 a piece.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Unregistered
![]() Glad you got it figured out. Now you have a good 'scuse to spend $$$ on one of them gold plated HDMI cables ..... assuming the monitor's new enuff. |
Don't need gold-plated for the HDMI...that's more of a marketing gimmick than anything. Aside from that, I'm with Sammy--go HDMI if your monitor/PC supports it.
Guy '87 944 (first porsche/project car) |
Unregistered
Remember when those cables first came out? Big bux, crazy money. They've come down quite a bit and are almost reasonable now. |
As a general note, cables are cheap on Amazon, Blue Jean and Monoprice.
Randy '87 911 Targa '17 Macan GTS |
The Unsettler
Top row, 1 = Red, 2 = Green, 3= Blue, 4 = ground or unused, 5= Ground Middle row, 1, 2, 3, and 5 = ground, 4= unused Bottom row, 1 = unused, 2 = DAT or unused , 3 = H Sync, 4= V Sync, 5 = Clock or unused
TV is a new Samsung Even with just a VGA cable the res is incredible.
I agree with the thinking what did I touch which was nothing except the cable and only at one end but I wiggled both plugs a couple times ,removed the cable twice and switch the ends around and still nothing but like I said I just moved the actual cable a tad ,not the plug and pic came back normal so the issue is where the cable goes into the plug. Of course that was at the end of the day after updating drivers and trying other things for hours. Last edited by lonewolf; 10-30-2013 at 09:24 AM.. |
The Unsettler
One of my guys asks if there was a problem? I said, "every new device comes with a power cord" He said, yeah pretty much, and? "Where are all the devices that these power cords came with?" Of course the answer was obvious but it really makes an impression on how much hardware even a building of 500 goes through over the years.
