Friend of Warren
Plaster wall refinishing question
Finally getting to work on a room I am making into my office/library. Home was built in 1926 and the walls are plaster. The room had wallpaper that I have removed. In one area (aproximately 12"x12") the plaster is damaged and needs to be replaced. That is something I can do. However the finish on the wall is rough and looks like it has fine grains of sand in it. I am repainting the whole room, but only this patch will have to have the sand finished added to it. Can I just add some fine sand to a small batch of the paint that I am using to repaint the whole room, or is it something I can add to the plaster? Here is a picture showing the finish. Thanks!
Kurt V No more Porsches, but a revolving number of motorcycles. |
Senior Member
Kurt,
Hope you get this figured out. I need to do the same thing (different pattern) in a couple of places in my house. Have heard that doing stuff like this is easy... course thats easy with years of experience! Joe A
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Band.
IMO you should fix the plaster then try to match the texture with a small batch of primer+sand. That way if you get it wrong you haven't ruined all your regular paint. If you can't get close enough then you could always consider the sand/paint thing with just that single wall, no need to retexture the whole room.
I just went trough a murderous round of wallpaper removal myself. 1928 house, no less than 2 layers of old, non-vinyled wallpaper on every wall, and every ceiling. I'm good at it now that it's over!! ![]() ![]()
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
Friend of Warren
Damn Jeremy, your project definitely is more involved than mine. Walls are in very good condition in the room I am working on and the wall paper came off fairly easily, with the exception of a few spots. I hate to retexture the whole wall if I can avoid it. I like your idea of using fine sand in the primer.
Home Depot sells a product in the paint dept. It is a small box of addative for a can of paint . I had to match a drywall repair to a sanded plaster wall in a florida house I had.
Results looked like sand added but was a lighter material like ground up plastic and stayed in suspension in the paint once mixed. Sand would be heavier and will need constant stirring while painting.
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 |
I'm sure that will work. And once you have painted the whole wall you won't notice it at all.
I've been refinishing some rooms that had very textured wallpaper and I'd cut various holes in for running wires and plumbing. I glued and screwed bits of drywall into place, plastered the particular bits, then sanded it in a circular motion with 40 grit sandpaper. Then evenness of the sheen/humpy bumpy-ness makes it even hard for me to spot where the holes have been. |
Friend of Warren
Thanks for the advice!
I'm with Bill
The few places in my house, also plaster that I have had to touch up I ran over the top coat with a roller while it was still wet. Blended right in but my "pattern" isn't as pronounced as yours.
Electrical problems on a pick-up will do that to a guy- 1990C4S |
