Band.
Replace cloth-wrapped wiring in conduit?
I've replaced the outdoor electrical service for my house.
My next electrical task -may be- to replace the old waxy-cloth covered wiring inside the house. All the wiring inside the house is (i'm guessing) a mid-20th century upgrade. All conduit, all the time. Inside the conduit are said waxy-cloth wires. So . . . . What say you? Do I need to replace this wiring if it's not 'broken?" If so, can I just remove it and shove some romex through the conduit? (if it will fit) I like the conduit, actually. The walls are plaster and lathe, so just shoving new wiring through the conduit is a quick and easy idea, if that's acceptable. thanks
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
Why not pull single wires through the conduit? Smaller diameter, less friction.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
OH sh it. Excuse me. Whatever you do, you have to replace that stuff.
Yes replace, but pull three singles through, no Romex. The first curve you get to you wil HATE pulling the Romex!
Cheaper too! Your best bet to pull will be to make a hook in the end of the existing and tie a loop in some string. Then tape the loop closed with a little taper up the wire to make it easy. Pull the string through, then pull the string through with the new wire done the same way. I'll let someone more experienced recommend the wire, we tend to run everything in 10 or 12ga THHN stranded since that's what we have to use to run up sign poles. Last edited by porsche4life; 11-23-2013 at 12:02 AM.. |
Hell Belcho
This man speaks the truth.
Saved by the buoyancy of citrus. |
Absolutely not Romex through conduits.
Use fish tape, hook wire to it and pull through. Having Conduits are much better then Romex. Why do you think you need to replace the cloth wiring? If you have conduit, then it isn't knob and tube (1920s). your existing wires inside the conduit should not heve cloth sheathing on it. Take a pic of it for us will ya? Maybe its that way in Colorado back then. My building restoration experience is limited to so cal. |
Used Up User
Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- Last edited by imcarthur; 11-23-2013 at 05:56 AM.. |
Parrothead member
No romex through conduit! Also conduit is not legal to use as a ground conductor. You have to run a separate ground.
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
Is this what you have?
![]() If the wires are not damaged then they do not need to be replaced, they should be solid copper. In our home the only wires that I have trouble with are ones in the ceilings. The heat from the lights breaks down the rubber insulation. I would concentrate more on running new circuits to places that you need more power, like bathrooms and kitchens. Pulling wires through bx can be done but 3/12awg wires is a tight fit, and all bx ends need bushings in them. This is all based on you having bx. If you have normal conduit it's a lot easier.
Peppy 2011 BMW 335d 1988 Targa 3.4 ![]() 2001 Jetta TDI dead 1982 Chevette Diesel SOLD
Quick and easy, as a part of home remodeling, is a surprise event - not a planned one. I've been rehabbing on and off for 25 years. I can count the quick and easy projects on my fingers. They usually cost twice as much and take 4 times as long. Of course I am figuring in the many trips to the hardware store. Its tough to get everything in one trip. Every trip to HD usually starts with a stop at the return counter because you always buy more than you need in an attempt to eliminate another visit. Seldom works for me.
Randy '87 911 Targa '17 Macan GTS |
Band.
Thanks, Dudes! Single wires it is!
![]() This house had knob and tube and got 'updated' to the nice, big, non-flexible conduit sometime. The wiring seems 'fine', except like Peppy here and there in overhead boxes where the heat has broken down the cloth. Quote:
Do I leave it or should I pull a green wire because I'm in there? Thanks!
Pull 3 wires, 12g preferred. If the existing wire is copper, you might just want to leave it. If it's aluminum, it definitely needs replacing. Just put a grounding rod near the panel for your ground.
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain Last edited by craigster59; 11-23-2013 at 07:15 AM.. |
If it that BX armored cable like peppy showed there is no way you are going to get just the wires out of there. I would guess that wiring dates to the 30's or 40's.
If the rubber is not deteriorated why not just leave it and make sure you have the right ground fittings on the jacket?
Rick 88 Cab |
Band.
Band.
It's copper. When I had my outside service done he did proper ground rods etc. so I'm getting closer to being correct.
Driver
We had the same issue in our 60 year-old house last year. A couple light switches started shorting out, prompting our "update." We had a handyman/electrician replace our wiring via the above sting-and-new wire technique. The insulation was intact, except for the ends (where connected to electrical switches) as that's where heat had broken down the insulating cloth over the years. The existing conduit made the job much easier (only 1 hole had to be made/patched).
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
Senior Member
And if you have room, go with the thicker gauge wiring. Its nice to have more capacity in the wiring than you have to have. Running a space heater at the end of a run can over task some smaller stranded wiring, so good to go up one size...
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Used Up User
No doubt about it, it will be a big job. You would have to map the wiring to locate the hidden junction boxes that may be lurking in the basement & attic or in closets etc. Buy 4 rolls of wire (add red for the 2nd hot lines as shown in the junction box you posted) & buy or make a cradle to feed them smoothly. A local electrical distributor would be a good source for supplies.
Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
Band.
Can I crimp the new wires to the old and use the old as my 'fish' line?
thanks everybody.
