Indoor bike trainer education needed
Now that I've been riding my bike more, I am looking to continue to use the bike throughout the winter. (One of the drawbacks of living in New Jersey: slush in the winter!) So I'm looking at indoor bicycle trainers. The price ranges are huge - $50 to $400+, and the options range too -- magnetic resistence, fluid resistence, multiple resistence levels...etc.
Ideally, I am looking for something that is compact, with adjustable resistence, priced around $100-$150. I don't know if any of these systems have computers to track 'virtual' mileage or speed, but that would be beneficial as well. What other options should I consider? What brands are good, and which ones should I avoid? Thanks, -Z
2010 Cayman S - 12-2020 - 2014 MINI Cooper S Coupe - 05-17 - 05-21 1989 944S2 - 06-01 - 01-14 Carpe Viam. <>< |
Slackerous Maximus
CycleOps Fluid 2. Love it.
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
I suggest you try one first. I can't ride those things more then 15 minutes if my life depended on it. since I live in paradise, so I am a little spoiled. A major of cycle fitness is cardio, so spinning at a certain RMP (90-100) is very important. Resistance adjustment on my unit has always been at its lowest setting. You can get a pretty god workout by keeping the pedal revs high. In your case, given the winter weather conditions, a little resistance on the trainer maybe a welcoming sign after days of spinning.
Black and Blue
Z-Man,
I dont ride as much as I should, but... I have a Kurt Kinetic fluid trainer with the front riser. I didnt know too much about trainers, still dont, but this one came up with high marks time and time again. I bought mine at REI. With this one, there is no adjustment for resistance but I can tell you that it gets harder to pedal as you go up in the gears. You can get a good wookout. Mine came with a training video and a special skewer you will need to use in the back. If you only have one bike, you might want to invest in another rear wheel with the same gear stack and buy a "trainer" tire. For some reason, trainers kinda chew up standard tires. Or if you dont mind changing tires, I guess you could spin on a trainer tire. Ive been mulling over the idea of dedicating a frame just to the trainer and welding up somthing to bolt to the front forks. If I had the cash, I would probably get a Computrainer or maybe the TACX Virtual trainer. im saving for another 911SC but the price keeps climbing at the same rate im saving
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
Skip it and sign up for a club that does indoor training using computrainers. I ride all winter here Connecticut Cycle Center |
I also have a fancy-pants Kurt kinetic rock-n-roll trainer....and have only used it twice.
10 E92 M3 13 Jeep GC Limited 98 Jeep Cherokee 87 951 C3 Stingray |
I actually like old fashion rollers. They are more fun because you actually have to keep your balance, and keep pedaling so there is no rest. It requires a little skill and they help build form. Lots of form.
. I bought a Travel Trak a hundred years ago for $90...just rigged it up again last week trying to lose 30 #s. . Travel Trac Comp Mag + Trainer - Bicycle Trainers . Happy spinning.
Don . "Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence." - - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View |
Just don't try this cheap, DIY method...
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Is there a gym near you, with a good spin class? You can always get a trial membership. Take a spin class. Choose a bike toward the back of the room, behind the girl with the best rear. Enjoy the view for five minutes, then suffer for 55 more. A spin class can be as much of a workout as you can handle, and it is efficient. Three a week will bring you into spring time way stronger on the bike than now, promise.
I did spinning twice. I think its dumb when they start with the push up on the handle bars as we were riding. That's because I am a wuss and have no upper body strength. After the actual ride, we ended up doing a bunch of floor exercise. I was totally gassed and did only a few sit ups while the pretty asses were kicking my ass. tough work out really. |
when i was getting out of biking, i could tell a lot of the new kids were not riding rollers. the bike skills just were not there.
z-your best option is to troll cl for a used Cyclops or Kurt. None of these trainers have odo or speed, but you can mount the sensor for a wireless bike computer on the rear stay and put the magnet on the back wheel.
Second the comments about tedium. You have no idea how tedious indoor trainer work can be. I have a computrainer that I can't stand to use. Get a good fan and put it where you can either read or watch tv. You may think it'll be tolerable b/c you've used a treadmill in the past, but a much shorter treadmill workout is effective. The tedium factor is why spinning and rollers are popular. I wouldn't recommend rollers to a semi-casual cyclist. I like them for the reasons that look171 stated, but they do require a certain mindset. Oh, I did weld up something for the front of my bike when using the ct, as it was not as stable as I wanted for doing sprint work. And a dedicated trainer bike is nice, if you can have one, as you'll drip sweat like a pig.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) Last edited by greglepore; 08-29-2013 at 04:54 AM.. |
(the shotguns)
Bought a Kurt Kinetics fluid and I've since decided i'd rather dress warm and be outside.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Z,
Like Greglapore said, I rather ride outside then to ride that trainer. Dress warm and a get set of winter tires if there's snow. When it snows, then come inside and do trainer work. Heck,just quit and have beer when it snows. The old saying goes, 30 minutes of light spinning road work is the same as 1 hour or more of hard turbo trainer workout. Its true. I think going around the block 50 times is A LOT more exciting then 15 minutes of riding the trainer in front of your favorite tv program |
Has anyone tried the Sufferfest videos? Sounds like they may have some potential .... from The Sufferfest on Vimeo.
1983 AUDI Turbo Ur quattro 1987 PORSCHE 944 turbo |
Model Citizen
So true. I've tried trainers twice, over the years; I wasted good money both times. I doubt if both those trainers combined had a hundred miles on them. BORE _RING!
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
I think that's how they get you. Every year they come up with something better with fluid, fan, friction, computer control, leans as you turn and on and on. This way we keep buying new ones only to not use them at all. I used my trainer a few times over they years. I am not sure who has them now, and I don't really care.
Kids, adults, even guys that have been riding for time, need to learn how to have good form. Rollers or track riding will force you to do that. You can tell if someone has good form in the first 30 second of riding. rock solid and relaxed upper body with legs moving only. |
