A930Rocket's Avatar
2001 Ford F150 SuperCrew with squeaky front end
2001 Ford F150 SuperCrew with squeaky front end when going over bumps, etc. I replaced the upper and lower control arms (that included new ball joints and bushings, along with new tie rods, steering components, etc. 4 years ago). Could it be worn out again in 20k miles?
To me, it's not squeaking bad, but according to my wife and son, it's terrrible.
Any ideas on lubing/greasing things as an alternative to replacing everything again?
Old 12-01-2013, 10:37 AM
Any rubber and or plastic bushings can squeak. I would try a can of silicone spray. Silicone won,t damage rubber or plastic .Directed at anything you can see. Sway bar bushings ,control arm bushings etc.
20k over 4 years says not worn out but dry from sitting long periods
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 12-01-2013, 11:13 AM
Make Bruins Great Again
Por_sha911's Avatar
There are those who disagree on this. Some say silicone is bad for rubber. Most will say that silicone spray has distillates which are certainly bad from rubber.
As a side note, silicone on paint is a disaster so if you must spray, do it carefully.
Joe
Old 12-01-2013, 01:13 PM
If concerned then read the can for cautions. I believe I have seen cans marked rubber lubricant and always assumed the contents were mostly silicone.
1995 993 coupe
2012 Boss 302
Old 12-01-2013, 01:34 PM
I had a squeaky Ford front end. Replaced sway bar bushings.
Old 12-01-2013, 03:43 PM
A930Rocket's Avatar
I've replaced the sway bar end links but not the bushings ill take a look at them.
Old 12-01-2013, 07:42 PM
Now in 993 land ...
aigel's Avatar
Many of the suspension and steering components are non-greasable these days. I have had good luck with a needle on my grease gun and some RTV to close up the hole. My 97 F150 had a terrible steering idler arm squeak. Non-greasable part. Fixed it for many years to to come with a grease injection to the boot!
I would however not just grease every part, rather than figure out what is squeaking first.
G
81 SC (sold)
Old 12-02-2013, 12:40 AM
