I'm sure an engine crankshaft was not designed to offer a certain amount of compliance. I would want it as rigid as can be. |
Certainly you want a stiff crankshaft, but the 70.4mm strokers aren't quite stiff enough for 8,000 rpm sustained. |
I would think that the maintainance of a critical gearbox and fatigue lifing of a shaft would be more expensive than replacing belts more frequently. Can a non-A&P change the belts? (Though the shaft would be more elegant than several stages of pulleys)
You would truly have to know the mechanics of the device to determine why it was design the way it was. Many things aren't observed until it has gone through extensive testing. |
Redundancy? Four belts so one can fail and no-one dies?
| All times are GMT -8. The time now is 11:24 AM. |
