-   -   Replacing outside breaker (http://forums.pelicanparts.com/off-topic-discussions/792472-replacing-outside-breaker.html)
Shaun @ Tru6 01-19-2014 07:41 AM
The breaker on the outside of my building is tripping when my silk screen dryer and flash dryer are on. Never used to.
Anyone ever change the breaker on a main box? Do I have the e- company turn off power to it?
http://forums.pelicanparts.com/uploa...1390146050.jpg
http://forums.pelicanparts.com/uploa...1390146065.jpg
http://forums.pelicanparts.com/uploa...1390146097.jpg
masraum 01-19-2014 08:37 AM
i don't think they are a big deal to replace, but someone with more knowledge can confirm. i think just make sure that everything they feed is off and replace. But don't take my word for it, wait for an expert.
craigster59 01-19-2014 08:46 AM
Is there a main breaker upline from that 3 pole 100 amp?
Shaun @ Tru6 01-19-2014 08:55 AM
Craig, I think this is the main breaker. Wires go from the pole to a huge steel conduit at the top of the building, that runs down to the box and meter.
craigster59 01-19-2014 09:07 AM
If that's the one that's tripping I'd call a professional, that's a lot of juice to get hit with!
Hugh R 01-19-2014 09:08 AM
I'd have the e-company pull the meter, you may just need to take a stiff wire brush to the buss bars.
Shaun @ Tru6 01-19-2014 09:18 AM
Thanks. E-company will only turn off juice. I don't think they will do it if I call and tell them too. Will call tomorrow and see.
Hugh R 01-19-2014 09:23 AM
E-company turns off juice, its dead, you take wire brush to the buss bars, and inspect/replace the breakers. Price out those breakers first, they could be no longer available. They look old and breakers, especially, old ones ,are known to fail just from taking them out and futzing with them.
Oracle 01-19-2014 09:24 AM
100 amp!! That will kill you if you don't know what you're doing. Please hire a professional.
IMO the breakers get old and trigger all the time when the load is close to limit.
Shaun @ Tru6 01-19-2014 09:38 AM
Great information, thanks. I'm hoping the E-company will turn off the e- with only my call.
this one looks similar
Siemens Q3100 100-Amp 3 Pole 240-Volt 10-Kaic Circuit Breaker - Amazon.com
mikesride 01-19-2014 10:04 AM
My house is 100 amp, its no big deal to add a new breaker with power on. They clip in and out, about as dangerous as flicking a light switch.
BUT......the breaker may just be doing its job!!!!
It is important to call someone in to insure that you do not have an electrical issue down the line that is causing the breaker to pop.
This happened everytime I turned on the toaster at home....
Then the toaster tried to electrocute me!!!! The issue was the worn out toaster not the breaker.
Shaun @ Tru6 01-19-2014 10:12 AM
OK, Mike, I'm taking you out of my will. :D
carambola 01-19-2014 10:20 AM
call an electrician, will your insurance company cover you if you do it incorrectly?
VINMAN 01-19-2014 10:29 AM
Shaun, being an electrician, the best advice I can give you is to have an electrician look at it. The breaker is tripping for a reason.
DanielDudley 01-19-2014 10:41 AM
Last time I screwed with the main breakers I wound up replacing the service panel and it took a day. Twas shot.
rick-l 01-19-2014 11:11 AM
Are your dryers 3 phase? I am just curious how they balance the loads.
Icemaster 01-19-2014 11:18 AM
What Vin said. Replacing a breaker, even a 3 pole is easy. Done it many times. You need to now WHY it's tripping. Better to have a pro verify the load. Be safe.
Shaun @ Tru6 01-19-2014 11:26 AM
The main dryer is 3-phase, the stand alone unit is just 110 in the wall on a 30A circuit.
Shaun @ Tru6 01-19-2014 11:28 AM
I'll see what I can do. It cost $4K to have an electrician install all this stuff, it's worked for 4 years now. the box outside gets constant weather exposure. I think it's just old.
I'm going to take the box cover off tomorrow and see what's in there. Can't hurt.
look 171 01-19-2014 12:00 PM
Shuan,
I don't think its the Breakers, but I have been known to be dead wrong. It might be something else that's tripping it. Cheap enough to change out the breakers and see if its still doing it. Hire someone to change out the breakers because it should be cheap enough to do if you feel uncomfortable doing it yourself. Its a 5 minute job.
