 A Lot Of Rotating Mass!!
		Very, Very cool
	<iframe width="640" height="360" src="//www.youtube.com/embed/Y0XbqHUAI-0?feature=player_detailpage" frameborder="0" allowfullscreen></iframe>  |
 That is a fantastic contraption
 If you think that is wacky in a car, try it in a plane
	<iframe width="560" height="315" src="//www.youtube.com/embed/L0-LXM8acEQ" frameborder="0" allowfullscreen></iframe> The idea behind rotary engines was that it enhanced cooling, and I believe the oil system used centrifugal force. Downside was the pronounced gyroscopic effects that coupled climbing and yawing making for interesting handling. By the way, no throttles on WW1 rotaries. Just ignition cuts.  |
 That is a fantastically scary looking thing there.  Love it.  Wouldn't want to work on it while it's running though.  Yikes!  :)
 That's crazy!!!  I luv it!
 ...and LMAO at the sound coming out of that plane posted by Flieger
 The airplane sounds that way because those radial rotary piston engines did not have a throttle. they ran wide open. the stutter you hear is whats called a blip switch, that is the only way to slow the engine down or make the plane lose alt.
	The blip switch kills ign to some cylinders to shut it down.  |
 So if the crankshaft stays stationary, what turns the wheels?
 What turns the wheels
 To think they did battle in these things. The planes must have killed more than the enemy...
 Very cool, dewolf, very cool.  Thanks for posting.
	I've read that with airplanes set up with motors like this, it was actually faster to go 270 degrees around to the left than to make a 90 degree right hand turn. I've seen several of this configuration run and fly at our local EAA fly-in in Arlington, WA. Amazing stuff.  |
 Major mechanical failure could be a bloody hazard to anyone passing by. Gives new meaning to throwing a rod.
 (I will bet that car still uses R12 for the AC)  |
 You think that's crazy?  How about a front-wheel-drive radial engine MOTORCYCLE?
	<object width="420" height="315"><param name="movie" value="//www.youtube.com/v/qAQuljp-atA?version=3&hl=en_US&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="//www.youtube.com/v/qAQuljp-atA?version=3&hl=en_US&rel=0" type="application/x-shockwave-flash" width="420" height="315" allowscriptaccess="always" allowfullscreen="true"></embed></object>  |
 Cheers JB  |
| All times are GMT -8. The time now is 01:43 AM. |
