Bosch distributor 911 T
Hello friends this time I consult on bosch distributors.
stiker says the alternator static timming 2-4 ° ATDC to 900rpm.
and dinamic 35 ° BTDC.
I use a lamp to lleverlo 2-4 ª ATDC at 900 rpm. But the car feels heavy engine. I wonder if I could be wrong on the information engine decal?
Distributor: Bosch 0231159008
Bake point: BOSCH / 1237013052
condecer: 237,330,292
coil: 0221102003
And has a Permatune module (be perhaps a CDI unit?)
I also read that it is good idea to use pertronik.
I beg your help.
Old 01-23-2014, 05:43 AM
Band.
Hello!
Set the high 6000 RPM advance to 33-35 first and then check the idle timing.
If the 6000 advance is correct 33-35 and the idle is not quite right then that is ok.
Does your distributor have vacuum retard?
My '72T distributor has vacuum retard, you must set the idle advance to 5degrees BTDC with the vacuum off, which makes it 5degrees ATDC with vacuum on.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 01-23-2014, 06:08 AM
Originally Posted by Gogar View Post
Hello!
Thank you very much for your help!
No. has no vacuum advance.
So you recommend me to regulate it in 600th rpm?
Old 01-23-2014, 12:24 PM
Gogar is correct. The important timing setting is at 6000 rpm. Use hearing protection when doing this as you are very close to the fan and the exhaust.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 01-23-2014, 03:28 PM
