cantdrv55's Avatar
Why do we droughts?
Why do we have droughts? Seriously and please be gentle with me.
Isn't the Earth mostly water? Don't we have the tech to make fresh out of the salty stuff? If "manufactured water" isn't fit for human consumption, can't there still be an available supply or source of it for doing laundry, etc?
Old 02-04-2014, 03:19 PM
porwolf's Avatar
Sure we have "tech". But at what price? It usualy requires expensive gear, high energy, high distribution costs. How much do you want to pay for water?
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 02-04-2014, 03:24 PM
AutoBahned
RWebb's Avatar
1. Why do we have droughts? Seriously and please be gentle with me.
2. Isn't the Earth mostly water?
3. Don't we have the tech to make fresh out of the salty stuff?
4. If "manufactured water" isn't fit for human consumption, can't there still be an available supply or source of it for doing laundry, etc?
1. Atmospheric conditions (including climate change, ocean temperatures, changes in the jet stream, & some of these are cyclical (PDO, El Nino); others are progressive such as global warming)
2. yes
3. yes, but see above
4. yes, but you'd need to replumb your house and your city
Old 02-04-2014, 03:28 PM
Air Medal or two
afterburn 549's Avatar
Not sure of i can help -
I am sure we as humans have a very limited concept of what times is.
How do we know its a drought? serious?
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 02-04-2014, 03:29 PM
Don Ro's Avatar
Thought for sure you'd mention the Horse Latitudes.
Don
"Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence."
- - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View
Old 02-04-2014, 03:39 PM
[QUOTE=RWebb;7892826]...
2. yes
OK, I'm gonna give you a chance to reconsider your answer (to the question) before I post anything more
Unregistered
sammyg2's Avatar
Desalinated water costs around $4 per thousand gallons, or an average of 40 cents per day per person.
That's pretty darned expensive compared to tap water. Too 'spensive to use for farming.
Plus you can't suck water out of the ocean to make fresh water without an intake pipe, and you can't have an intake pipe without the damned tree-huggers filing a lawsuit over some tiny fish or crab that might get sucked in.
In fact they convinced the brain-dead congress to make ocean intake pipes illegal cause they might kill plankton.
The law they passed that prevents desalination plants from taking sea water and making it into fresh clean water?
The clean water act. I sheet you not.
Old 02-04-2014, 03:45 PM
Unregistered
sammyg2's Avatar
[QUOTE=KC911;7892851]
2. yes
Algore manbearpig says the center of the earth is millions of degrees F.
Missed it by that much .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................
Old 02-04-2014, 03:50 PM
porwolf's Avatar
1. Atmospheric conditions (including climate change, ocean temperatures, changes in the jet stream, & some of these are cyclical (PDO, El Nino); others are progressive such as global warming)......
The main reason for "droughts" is probably beacuse we prefer to live in areas that are basically dry. The Southern California area, for example, was not made for 20 million people living the modern life style.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 02-04-2014, 03:55 PM
least common denominator
scottmandue's Avatar
Originally Posted by porwolf View Post
The main reason for "droughts" is probably because we prefer to live in areas that are basically dry. The Southern California area for example was not made for 20 million people living the modern life style.
That is why I'm moving to Las Vegas!!!!
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 02-04-2014, 04:04 PM
Bollweevil
Desalinization might supply drinking water for coastal areas but that is about it. I am old enough to remember the 7+ year drought in TX from 1950- 1957. The states economy was just recovering from the drought of the dust bowl years and depression when this drought started. It went on and on and nearly destroyed the states economy which was mostly agriculture based and started the mass shift from a mostly rural agricultural population to the cities.
The population of the state is now probably 10 times what it was in the 50's. Another drought like that would be an unmitigated disaster and not a damned thing anyone could do about it. No place to run or hide when it doesn't rain... and you can't drink oil.
Jack
74 911 Coupe
2.7L - K21 Option - S suspension
Old 02-04-2014, 04:44 PM
Banned
you have failed to do a proper rain dance
Old 02-04-2014, 05:05 PM
jyl jyl is online now
jyl's Avatar
Multi layered topic.
On one level, it is because our cities and agriculture use and waste water as if it were an abundant and cheap resource. That's why all the shower water, dishwater, sink water you use - 75% of your household water use - gets discarded to the ocean instead of reused for toilets, irrigation, industrial uses. That's why crops are grown in the Central Valley with spray irrigation and no evaporation barriers. That's why people living in deserts have bluegrass grass lawns. If the US used water at a gal/ household rate like most other countries, there would be no shortage of water in California, or Texas for that matter. Average Water Use Per Person Per Day
On another level, there would still be a drought, for the forests and mountains and rivers. That is partly cyclical and partly climate change-driven.
Old 02-04-2014, 05:21 PM
Fleabit peanut monkey
Bob Kontak's Avatar
There is more water within the earth's mantle than on top of the crust.
Just sayin'.
1981 911SC Targa
Old 02-04-2014, 07:08 PM
Detached Member
Hugh R's Avatar
I did an environmental due diligence for insurance on the De-Sal Plant in downtown Santa Barbara 20 years ago, it was pretty interesting. The City/County is now talking about reviving that plant. They ran an intake pipe inside an old sewage pipe that went a mile or two out into the ocean.
If you think about it, De-Sal plants make a lot of sense with nukes. They need cooling water, seawater turns to steam which is pure water vapor. Put in another seawater cooling loop and turn the steam into condensed fresh water.
Hugh
Old 02-04-2014, 09:13 PM
RETIRED
Joe Bob's Avatar
They dismantled the plant and sold it to the middle east........
2012 ML350 3.0 Turbo Diesel
Old 02-04-2014, 09:42 PM
Detached Member
Hugh R's Avatar
Actually I don't think so. I saw an article a few days ago in the LA Time where it is still there. They sold the filters to someone.
Here:
Restarting Desalination Plant Would Cost $20 Million | News - KEYT
Hugh
Old 02-04-2014, 09:53 PM
ckissick's Avatar
Here's an interesting article.
Is the West's Dry Spell Really a Megadrought? | Climate Central
Charlie
1966 912 Polo Red
1950 VW Bug
1983 VW Westfalia; 1989 VW Syncro Tristar Doka
Old 02-04-2014, 10:27 PM
madmmac's Avatar
I wrote a sci fi thriller in the 4th grade about man trying to harness mother nature by manipulating the currents in the oceans to alleviate droughts and lessen the impact of poor weather.
In the story, if you were not in a fairly close proximity to either of the poles, it did not end well for you.
The teacher thought it was pretty gruesome and alarming but still gave me an A.
With all the CGI now it would play out as a pretty good movie scenario.
Don't mess with Mother Nature.
madmmac AKA Mitch
1984 Factory Turbo Look
2006 4Runner
1998 TRD Supercharged 4Runner (Sleeper)
Old 02-04-2014, 11:30 PM
Laneco's Avatar
Originally Posted by ckissick View Post
Someone shared this with me the other day and it certainly presents some concerns... We tend to look at climate very myopically. We look at it in relation to very recent past which does not present adequate data to tell us anything but micro-changes. Climate, geology, etc., require us to look well beyond the last 100 or 200 years. California may have been in an abnormally wet period when it was settled and farmed. When it becomes "normal" which is much drier if this and other sources are accurate, it will be quite a disaster for the cities and for agriculture.
angela
Hello
Old 02-05-2014, 08:25 AM
