Bench top grinder is my friend. I am the only idiot that sharpen drill bits. None of my guys do it and they will keep turning that damn thing until they burn the house down or even easier, they go and get a new one. Onve every few months, I sit by the bench grinder, coffee in hand and somehow, 20-30 min later, they are all sharp again.
Match up the lip angle and gently touch the grinding wheel. Its all you will need. Try and not get past the chisel edge. Repart on the other side. It takes 15 seconds. Don't jam the damn thing in there. Light pressure is all it takes. It is as good as a pro, or the drill doctor? Hell no, but its about 90-95% as good.
Oh have some water ready to cool off larger bits.
Old 12-09-2020, 05:08 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Originally Posted by peppy View Post
+1 on the drill DR.
The best thing I have done for drilling metal is step bits. I've had a set for 15 years and I still use them on a regular basis, they are a bit dull but you can put a lot or pressure on one,
Just bought step bits to make a hole in an exhaust pipe for a welded in OXY sensor bung. I was impressed with the cutting.
1981 911SC Targa
Old 12-09-2020, 05:15 PM
Bob Kontak's Avatar
Originally Posted by Por_sha911 View Post
There are titanium coated bits, carbon steel bits, hardened steel bits. Does one machine handle all those different metals?
The $60 drill doc "sharpens standard drill bits".
It's a diamond grinding wheel. Suspect if the collet can grab it it will grind it to the chosen angle - which is 118 degrees on the $60 jobbie.
1981 911SC Targa
Old 12-09-2020, 05:35 PM
908/930 sums it up perfectly! I'm a custom furniture maker and I sharpen all of my own bits, of all different styles. I use many different materials in my work and sharpen accordingly, wood, plastics, ferrous and nonferrous metals. Just look at what needs to be achieved and how to get there. I use no jigs or gadgets which will only clutter collect dust and be forgotten about anyway.
Old 12-10-2020, 03:48 AM
Bob Kontak's Avatar
Why muddy the waters with facts.
I'll do a little testing with the Drill Doctor as almost every drill I have is a perfect before/after candidate.
With respect to the Best Set of Drills thread, my best set is the two Dewalt 1/4" titanium coated ones I bought two days ago.
1981 911SC Targa
Old 12-10-2020, 07:11 AM
The Project Farm YouTube channel had a video on the different sharpeners as well. DD did well.
Brent
Old 12-10-2020, 07:25 AM
I thought everyone just took new drill bits from their workplace. That's what I do.
Old 12-10-2020, 09:02 AM
Counterclockwise?
Is it just me that collects old/dull drill bits?
I inherited most from my father who had the same infliction!
Maybe I should sharpen them.
Rod
1986 Carrera
2001 996TT
Old 12-10-2020, 09:14 AM
Jeff Alton's Avatar
My Drill Doctor is one of the best things I ever bought for my shop.
This....
Have had one for about 18 years......
www.turn3autosport.com
Old 12-10-2020, 11:22 PM
I have the higher end (provides for smaller diameters) DD. Works fine - been using it for years.
Sold: 1989 3.2 coupe, 112k miles
Old 12-11-2020, 07:49 AM
