Banned
Histogram on Digital Cameras
Can anyone explain the Histogram displays on digital cameras to me?
Google searches not that helpful...
Old 03-30-2014, 04:09 PM
Registered Usurper
DARISC's Avatar
Did you Google this? Understanding Histograms
'82 SC RoW coupe
Old 03-30-2014, 04:22 PM
AFC-911's Avatar
Too much to the left means it's underexposed (too dark). Too much to the right means it's overexposed (too bright).
Ideally, it should be mostly in the middle.
You should also use the light meter if you have a dslr. Same concept except it tells you if it's under or overexposed before you take the shot.
if the graph clips on one side, then you lost detail on that side. With most digital cameras, you're better off being slightly overexposed than underexposed.
Old 03-30-2014, 08:53 PM
You may find this interesting.
Are you Shooting HAMSTTR? - ETTR - Expose to the right - Canon Digital Photography Forums
Old 03-30-2014, 09:04 PM
Banned
It depends on what you are shooting. If it is dark and it's supposed to be dark it will be to the left. If it goes off the edges it means that detail is lost and you won't recover it in post.
Old 03-30-2014, 10:30 PM
+1
Very good method to get light right!
I also agree with AFC-911 on using the DSLR's built-in light metering functionality - the camera will tell you in advance if you are over or under exposing.
'70 911T (AKA Bottomless Pit) - Undergoing restoration
'13 Audi A4 1.8T - Surprisingly fun means of getting to work
Old 03-31-2014, 07:51 AM
