Somewhere in the Midwest
MotoSook's Avatar
If the wheel is stuck...just use a 1/2" impact socket and breaker bar with a pipe for extension. The stud will break. Trust me it will break.
I replaced studs on all four corners of a buddy's SpecMiata. It ain't rocket science. The caliper is easily removed and a 3 lbs sledge popped the studs right out with no damage. Then I used a large nut that fits over the stud as a spacer (you can use the wheel too like I suggested earlier) and pulled the new stud through. Use washers on both sides of the spacer nut and lube with grease. An impact wrench pulls the stud through in seconds.
Don't over think this. You don't need to remove the hub nor a press. We do this on Porsche hubs too.
Old 04-04-2014, 10:22 PM
least common denominator
scottmandue's Avatar
Thought I had posted a reply but don't see it here.
I'm at work now and dad just went into the hospital so may not get to it today or tomorrow.
I don't have a impact wrench but I do have a small sledge and lots of repressed anger.
Update, just called Autozone and they have a stud in stock! I do have Monday off so I can attack it then.
"Thanks for your support!"
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 04-05-2014, 04:31 PM
Gallatin, Tennessee
Hope you dad gets better. The car can wait.
Dave
Old 04-05-2014, 04:38 PM
Dave
+1 get well soon scottmandue's dad.
good luck with the car when you get to it.
Old 04-05-2014, 06:42 PM
JW Apostate
trekkor's Avatar
Yes, easy to replace. Good chance the local parts store will have on in stock for a few bucks.
'74 914-6 2.6 SS #746
'01 Boxster
Old 04-05-2014, 09:38 PM
fastfredracing's Avatar
I have worked in and around garages for 25 some years, and cannot remember the last time I have seen anybody use a press to replace a wheel stud,
The problem with removing the hub is that it will most likely be stuck in the knuckle, and you will have to pound the piss out of it to remove it, most likely destroying it. You risk making a 30 minute $15.00 job a two hour $200.00 job. Just smack the stud out with a hammer, and pull the new one in. May want to grab an extra lug nut, sometimes they get boogered pulling the new stud in. This is how it is done in a shop .
I also think trying to chock upa one piece sealed bearing/hub in the press to shove in a new stud, would be akin to watching a monkey hump a football.
Hope your dad gets better.
No left turn un stoned
Old 04-06-2014, 05:05 AM
AKA SportsCarFan
FastCarFan's Avatar
"Striped nut" - If you don't like the stripes, just paint it.
Doug Miller
1988 Guards Red Carrera
Old 04-06-2014, 08:41 AM
