electrical tape use under the hood, where to buy or what type?
Factory electrical tape is good stuff, but where to get this stuff. Most of my electrical tape will come apart within months when used under the hood. I suppose from the heat? There are some stuff I like to tape up in my diesel truck for slightly better protection. Where do they get this stuff and what is it called. Normally they look like cloth tape on the outside but they really stay put pretty well under there for a long time. My truck is a 93 and that tape that's on there is still , well on there pretty damn good.
Old 04-07-2014, 01:41 AM
I see some of this stuff on ebay but don't know if its good or not. I bought a small roll from Autozone that seem very much like the ones on ebay or factory, but it came apart in months.
Old 04-07-2014, 01:45 AM
Almost Banned Once
sc_rufctr's Avatar
There is a genuine VW tape listed in their parts catalog. It's the cloth tape that's used on the engine wiring loom and the main wiring under/behind the dash.
But it's not cheap... About $12 a roll from memory. (50 meters)
I've also used self amalgamating tape. It reacts and sticks to itself. It really works well.
Also... You can extend the life of standard electricians tape by securing the end with a small zip tie. It stops it unwinding when heated but still not as good as the cloth tape.
- Peter
Old 04-07-2014, 01:55 AM
Air Medal or two
afterburn 549's Avatar
Most any hardware store sells good tape. The stuff sold at out lets is crap .
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 04-07-2014, 02:56 AM
Serial Lurker
ledhedsymbols's Avatar
Send a message via AIM to ledhedsymbols
I use this stuff at work for anything that matters.
Scotch Super 33+ Vinyl Electrical Tape :3M US
Scotch Super Vinyl Electrical Tape 88 :3M US
Check an electrical supply house. You MAY find the Super 33+ at a box store
Does anyone know where the love of god goes when the waves turn the minutes to hours?
Old 04-07-2014, 03:24 AM
Slippery Slope Victim
NY65912's Avatar
This tape from ECS is great. I use it on my Audi whenever I do electrical work on it. Very sticky and is 100% the same as what is used originally.
http://www.ecstuning.com/Audi-TT_MKI-Quattro-225HP/General_Purpose/Tape/ES10764/
Mike²
1985 M491
Old 04-07-2014, 03:59 AM
KNS KNS is offline
I've picked up what is probably the exact same cloth tape from a Mercedes dealer, not cheap but I think it's made to withstand the heat of the engine bay and it looks correct.
Kurt
Old 04-07-2014, 04:41 AM
Professional Bull5hiter
Outback Porsche's Avatar
I use a self vulcanizing/amalgamating tape.
Jeff
83 944 Guards Red
23 718 GT Silver
Old 04-07-2014, 04:48 AM
Cloth tape sold as friction tape at electrical supply houses.
It'll still unravel on you. Cover it in the Super 33+ mentioned above. It's about the best tape you can buy.
Pull tight as you're wrapping, and relax the tape for the last couple of laps. Pulling tight at the ends will cause the unraveling.
Carter
Old 04-07-2014, 06:11 AM
Gallatin, Tennessee
Originally Posted by NotaBRG View Post
+1
The 33+ is good stuff.
+2
That is the only electrical tape I use.
Dave
Old 04-07-2014, 06:23 AM
one of gods prototypes
bell's Avatar
33 is the stuff, I've built entire car harnesses using it and never had an issue. ..... Ever
Old 04-07-2014, 08:50 AM
Almost Banned Once
sc_rufctr's Avatar
I get mine from Jaycar.
- Peter
Old 04-07-2014, 08:59 AM
We use 3m fiberglass tape up to 150C (302f) with no issues. It is great for abrasion and heat resistance.
07 Exige S
Old 04-07-2014, 09:04 AM
The 3M that comes in the little plastic box is the good stuff!
Old 04-07-2014, 09:26 AM
Thanks. I knew that would be an easy one for you guys
Old 04-07-2014, 09:33 AM
Bollweevil
Carter
This is the mistake a lot of people make when using electrical tape... guaranteed to unravel if you stretch it the last couple of turns.
Jack
74 911 Coupe
2.7L - K21 Option - S suspension
Old 04-07-2014, 10:41 AM
Yeah huh!
Years of electrical work. Maybe more like decades.
BTW, heat/oil will exascerbate the unraveling once it starts.
Carter
Old 04-08-2014, 05:27 AM
83 911 Production Cab #10
JJ 911SC's Avatar
$3.98 at Lowes
Shop Scotch Super 33+ 3/4-in x 66-ft Professional Electrical Tape at Lowes.com
Who Will Live... Will See
Old 04-08-2014, 07:12 AM
Run smooth, run fast
Heel n Toe's Avatar
Use any kind of electrical tape you have on hand, then once you're done, secure it with either one zip tie centered on the taped area/join, or two zip ties; 1/8 of an inch in from each end of the taped area/join.
- John
Old 04-09-2014, 02:14 AM
