-   -   Tire size (http://forums.pelicanparts.com/off-topic-discussions/805433-tire-size.html)
BUCKO 04-09-2014 10:45 AM
Tire size
CURRENTLY ,MY 1971 911 HAS P225/50R16 tires on the rear, can i replace those tires with P245/45R16.Looks like i have the room but i would feel better with other opinions
thankyou: Bucko
Vipergrün 04-09-2014 10:49 AM
What size is the wheel? That will play into it too. I had 245/45/16 on my 80SC, but on 9" Fuchs, had plenty of room.
Joe Bob 04-09-2014 10:59 AM
Best to have an 8 inch wheel....then if you're lucky enough to find a fresh set of 245/45s......
emcon5 04-09-2014 11:16 AM
I ran 245-45-16 on back of my SC on 8" BBS, and it worked well (with 225/50 in front).
I eventually went back to the stock sizes because street tires in 245-45-16 dried up. Only one option and it is softer than I want in a street tire, and more expensive.
BUCKO 04-09-2014 01:32 PM
THANKS GUYS I HAVE 8 INCH WHEELS AND FOUND A FRESH SET OF TIRES ,BUT GET THIS $150.00 FOR ALL FOUR,NOT NEW BUT WAY BETTER THEN WHAT I CURRENTLY HAVE
THANKS FOR ALL YOUR INPUTSmileWavy
Heel n Toe 04-09-2014 11:08 PM
You know how to tell how old the tires are so you know they're not unsafe, don't you? They might not even be worth $150. You don't want to cheap out on tires.
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=11
