Tire size
CURRENTLY ,MY 1971 911 HAS P225/50R16 tires on the rear, can i replace those tires with P245/45R16.Looks like i have the room but i would feel better with other opinions
thankyou: Bucko
Old 04-09-2014, 10:45 AM
Formerly bb80sc
Vipergrün's Avatar
What size is the wheel? That will play into it too. I had 245/45/16 on my 80SC, but on 9" Fuchs, had plenty of room.
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 04-09-2014, 10:49 AM
RETIRED
Joe Bob's Avatar
Best to have an 8 inch wheel....then if you're lucky enough to find a fresh set of 245/45s......
2012 ML350 3.0 Turbo Diesel
Old 04-09-2014, 10:59 AM
Hilbilly Deluxe
emcon5's Avatar
I ran 245-45-16 on back of my SC on 8" BBS, and it worked well (with 225/50 in front).
I eventually went back to the stock sizes because street tires in 245-45-16 dried up. Only one option and it is softer than I want in a street tire, and more expensive.
82 911SC Coupe
GTI Cup #43
Old 04-09-2014, 11:16 AM
THANKS GUYS I HAVE 8 INCH WHEELS AND FOUND A FRESH SET OF TIRES ,BUT GET THIS $150.00 FOR ALL FOUR,NOT NEW BUT WAY BETTER THEN WHAT I CURRENTLY HAVE
THANKS FOR ALL YOUR INPUT
Old 04-09-2014, 01:32 PM
Run smooth, run fast
Heel n Toe's Avatar
You know how to tell how old the tires are so you know they're not unsafe, don't you? They might not even be worth $150. You don't want to cheap out on tires.
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=11
- John
Old 04-09-2014, 11:08 PM
