Recreational Mechanic
Tapping for an NPT tapered drainplug - Help?
Anyone have experience drilling/tapping for an NPT tapered plug? I have a tapered NPT tap, but do I need a tapered drill bit to make the hole? Or just use a regular parallel drill bit on my drill press?
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
Un-Registered User
Straight drill. You can find a chart online for the tap drill size. I just did one yesterday. What size?
Don 1988 Targa |
3/4". Just found it. Drill size is 59/64ths. Fortunately I happen to have a bit that size!! Tapping a factory drainplug into my Corvair differential case. They quit putting in drainplugs after '63.
UnRegistered User
Start square.
Go slow. Try the plug in the hole when you have threads all the way through. You should have about 3 full rotations of the plug by hand before you start to feel some resistance. In other words, you can't make the threaded hole smaller!
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
I also learned that you have to use an NPTF "dryseal" tap. If you use a regular NPT tap then it will leak unless you put pipe sealer on it.
When I learned to tap threads in the old days.....1963, I started using Crisco. It absorbs heat, melts and lubes the cutting very well. I have a small can that is about 25 years old and will be around after I am gone probably. Yes, there are a lot of nice, new modern lubes, but.......
12 rotations of the tap usually gets you to size, a Bill says check. After about 8 turns of the tap it is good to start checking.
drew1 wife has 924 turbo |
