Wheel corrosion repair
I'm looking for some suggestions on repairing the corrosion damage on my FX35 wheels. It's pretty much limited to the area around the metal valve stems. I'd like to do something on the cheap, but I'm afraid that the stems need to be removed for the repair to survive a Wisconsin winter. Obviously the paint wasn't sealed in this area originally. Of course I would need to remove the tires from the wheels to remove the stems. At that point I may as well have the entire wheel refinished, but I fear that the new finish may not survive the process of remounting the tires.
Here's a couple of pictures of one wheel, they all look pretty much the same. ![]()
That looks like rust. Are those painted steel?
Get them powder coated. They will survive anything.
1986 911 Targa We affirm that the world’s magnificence has been enriched by a new beauty: the beauty of speed. A racing car whose hood is adorned with great pipes, like serpents of explosive breath - a roaring car that seems to ride on grapeshot.... |
Driver
I do not do this stuff for a living, but looking at those wheels, I'd guess that the proper way to do the repair is to dismount the tires and valve stems, clean off the corrosion down to bare aluminum, and then repaint/powdercoat/chrome/PVD or however you want to cover them. Then reinstall the tires. That corrosion is going to compromise the seal at the valvestem, and you're going to develop slow leaks. I think if you do something on the cheap, your repair is not going to last.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
Control Group
How much to refinish a wheel, and would that compromise the strength of it?
She was the kindest person I ever met |
I don't see why media blasting and paint would compromise the strength. I have read some mention of powder painting (400°F) altering the metallurgical characteristics of the aluminum, don't know if that's true. |
Got to couple of car dealers and ask who they use for wheel repair. Most wheel repair guys can fix that in their work vans. They can even match the paint, but the mobile repair guy here hates doing that finish.
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
Still Doin Time
I have one word: Wheel Collision Center Bath PA- Excellence in Refinished/Used Factory OEM Aluminum Alloy Wheel Rim Sales & Alloy Wheel Rim Straightening Repair Refinishing & Recycling! - www.oemfactoryrimwheel.com Excellence in Refinished/Used Factory OEM Aluminum A they are w/o a doubt the best place, service and price. You'll need to dismount the tire and send it to them. Anything else is just a temp repair
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
Wheel Collison Center is great, but they're local to me.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Control Group
I was thinking of the corrosion weakening the rim. Given where that is, I would be suspicious of something internal, rather than external. Wet air that then condenses, or something like that.
300hp 1800lbs is the goal
Galvanic corrosion? Is that valve stem making any metal on metal contact? Perhaps on the inner surface of the wheel? Aluminum is one of the worst, especially if stainless is touching it.
Looks like rusting steel to me, but I really doubt any infinity would come with steel wheels. You're not the first with this problem... FX35 oem wheels corrosion on google pulls up same isssue with someone else.
The '66 912 Bastardization project has begun. Note to PO's: LAY OFF THE FREAKING BONDO!!!! The science was settled: Earth was flat. Galileo : Flat Earth denier.
